Summer time start up
Old Jul 25, 2013 | 11:47 PM
Thore's Avatar
Before I pull the trigger on ordering up parts, I just wanted to verify I'm going in the right direction.
Issues I'm experiencing only seem to happen when it's hot out (90+ degrees). When I start up, the car runs roughs and has more of a loppy idle. Sounds good actually but I know it's not normal. I notice the wideband shoots leans if I let it idle for a good, but tends to go away completely when I drive around. It hasn't been a huge problem and I can easily ignore it, but maybe there is something to gain by fixing this.
I'm guessing this is caused by vapor lock or the fuel rail heat soaking from the engine/intake manifold? It gets hot in the engine bay this time of year.
To combat this, I was thinking of installing a Phenolic intake manifold spacer/gasket along with removing/disabling the EGR.
Any input would be greatly appreciated.
Old Jul 26, 2013 | 09:58 AM
ProPilot04's Avatar
Vapor lock will usually prevent the car from starting, not cause a strange idle.
You can check to see if it's vapor lock by checking your fuel pressure.
Old Jul 27, 2013 | 11:48 AM
Thore's Avatar
I'm going to guess and say, because my fuel pressure stays consistently at 40psi at idle, it isn't a fuel delivery issue.
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
Murder Snake
Jul 1, 2014 09:01 AM
JTCB
May 31, 2014 07:22 AM
EVO261230
Jul 25, 2013 10:01 PM
Slickonice
11
Jan 13, 2013 09:06 AM
