Compression results
Old Jul 31, 2013 | 01:30 AM
pughdxk's Avatar
Throttle closed never did a conpression test before
Old Jul 31, 2013 | 02:32 AM
Macaroni's Avatar
Originally Posted by craig05evo
FYI, when you retest, unplug the coil packs from the harness and I think you need to unplug the relay for the fuel pump so you are not dumping fuel in the cylinders.
Wouldn't it just be easier to unplug the CPS?
Old Jul 31, 2013 | 06:10 AM
craig05evo's Avatar
I heard that worked, but I have never tried it that way. To the OP, test it warm with the throttle full open, my guess is you will be happily surprised.
Old Aug 1, 2013 | 08:38 PM
steven121's Avatar
Originally Posted by BEKevo
Dang. Must be the rings then. You're borderline below the acceptable "variance" (~15%) across the board. Are you having any of the symptoms of worn rings (i.e. burning/consuming oil, tough starts, idle instability etc..)?? If none of the above are too bad, I would ride it out for another 3,000 and check again. Just to see a trend.. Unless you just want to replace the rings now... And dont forget, like mentioned above me, do this all at or around operating temp (180ishF)
Well now when i drive the idle will drop below 800 like it stalls and will idle back up again normal, it seems to idle just fine, but it would consume oil before with my 9 turbo but with the new turbo oil consumption isnt that bad
lostsoulsevo
28
Feb 9, 2017 05:52 PM
b0yw0nder
Jun 4, 2016 06:37 PM
tzoyi
Dec 12, 2015 07:30 AM
Eno-Evo
Oct 13, 2015 10:48 AM
fullm00nevo
Jun 9, 2015 12:30 PM
