Greddy Type S BOV or Evo 9 BOV?
Old Jul 28, 2013 | 04:42 AM
whotippedmycow's Avatar
I recently purchased a Greddy Type-S Bov. Does anyone know what PSI it holds upto or should I purchase a Tial Q or Evo 9 Bov? Also whats the difference between Evo 9 BOV and Diverter? I am trying to find one of these now so I can get tuned asap. Thanks!
Old Jul 28, 2013 | 08:08 AM
impact blue's Avatar
I'm not sure what psi it holds up to but just make sure its a legit one because if made cheaply it will leak and may cause mechanical damage.
I had a tial before its very quiet. If your going to use a Evo 9 bov make sure to use a MR its metallic and not plastic like the base model gsr that's what you want the MR model if you do that.
Old Jul 28, 2013 | 08:21 AM
Thanks! I'm pretty sure its legit but still curious if its better then the stock 8 bov?
Old Jul 28, 2013 | 08:38 AM
gsrboi80's Avatar
In the states all VIII DV's were plastic in all trims including the MR. JDM MR DV was metal
All IX DV's are metal.
Old Jul 28, 2013 | 08:46 AM
SSMCL9's Avatar
I had a greddy type s and it does leak at around 20psi. if you still insist on using the type s bov you will need to buy the diaphram made for the type s bov from NRG.
Old Jul 28, 2013 | 09:03 AM
djdnav's Avatar
Even real Greddy valves leak, I'm not sure why anyone buys from them anymore. Tial qr or Evo 9.
Old Jul 28, 2013 | 09:09 AM
05evoGSR's Avatar
been running a greddy type-s for 7 years at 25+ psi with no leaks. just make sure you don't mount it near extreme heat or the rubber diaphragm will dry out and crack. i think its and excellent BOV, not sure why they switched to the type-RS
Old Jul 28, 2013 | 09:12 AM
Whats the difference in the springs for the QR?
Old Jul 28, 2013 | 09:58 AM
djdnav's Avatar
the tial q is VTA, and the QR is recirculated. I dont know the spring pressure.
Old Jul 28, 2013 | 10:05 AM
90zcrex's Avatar
Everyone hates on the type s. They are older so the diaphrams are usually not in great shape, I got a new one from greddy and it held 30 psi no problem.
Old Jul 28, 2013 | 11:32 AM
Anyone know where to get a new diaphragm from NGR cheap?
Old Jul 28, 2013 | 11:39 AM
adriano_917's Avatar
Back when I had my srt4 I had the type s and it leaked at 18psi, I later switched to the rs which it hold 18psi no problem. 2 yrs later I sold the srt4 with the type s and kept the rs for the evo but it wasnt working good on the evo(recirculated) so I bought a Tial qr and up until today it holds 28psi no problem.
Old Jul 28, 2013 | 11:42 AM
I know the QR is the way togo but I already have the Type-S. If replacing the diaphragm is cheap then may be worth it since I am only pushing stock boost.
Old Jul 28, 2013 | 11:47 AM
Go to http://www.ngrperformance.com/blackngr.php they make a "type s" bov and they sell the diagraphm for $40.
Old Jul 28, 2013 | 11:58 AM
appreciate it
