EVO 7 AYC 3 lights - advice needed
Old Aug 21, 2013 | 07:30 AM
Nero_slk's Avatar
Question EVO 7 AYC 3 lights - advice needed
Hi,
Did the diagnostics and got this
As I understand its -
Both front speed sensors code 11 and 12 on ABS (ABS light is OFF while driving, never knew that I even have problems with it)
And code 82 on AYC..
Can the speed sensors affect the AYC - as the ecu doesnt undersrand the speed?
The AYC was working fine since I bought the car, but after 300 miles all 3 light came on.... when I start the car ive got 1 light and can select mods, only after 200~meters all 3 come on-so I think its not the pump..
Im doing my brake pads on friday, is there anything i can clean (location for the sensors?) to possible try to sort out this problem?)
Is there a way to reset these codes?
Any ideas or advice are more than welcome!!
Huge thx for all your help!
Regards
Dimitry
Old Aug 21, 2013 | 08:21 AM
Nero_slk's Avatar
did a diagnostic suggested by a mate who owns a evo 8 ..
Ignition on- after 5sec press the accelerator pedal to the metal and hear if the pump is working and shutting down in 10secs..
what happens-
swich the ignition on, it rememberes that before the error it was in gravel mode...
-press the gas pedal and wait 10 secs (cant hear anything)
-after approx 10 secs my AYC lights come on...
So as i understand the pump isint working at all? and im thinking it could be the fuse/relay/power issue to the pump?
Am i correct? is there anything i can do to further diagnose this?
Cheers :>
Old Aug 22, 2013 | 03:34 AM
Nero_slk's Avatar
Anyone? :/
Old Aug 22, 2013 | 04:21 AM
ronaldo9's Avatar
If the fuse is ok it could just be mechanical failure and you,'ll need t rebuild it or buy a new one.
Old Aug 22, 2013 | 05:09 AM
Nero_slk's Avatar
But where is the fuse for it?? Could not see it under the bonnet, and nothing inside ...
Heard it has a relay too-so ideally would like to check all of that
Old Aug 23, 2013 | 12:49 AM
iTzMe's Avatar
Try bleeding the pump. I had the same problem recently I had to replace the abs sensor and pump. Right now there's only one company that rebuilds pumps but he has no parts. Matthew from http://www.acd-tuning.com/
daasca
May 16, 2016 05:08 PM
browningderek
Jul 11, 2013 02:36 PM
Mr Supra
Jul 14, 2012 06:44 PM
Crester
Toronto Lancer Club
Jan 3, 2012 01:20 PM
5speedwtneed
Dec 7, 2011 02:51 PM
