GSC R2 11:1 2.3L Idle video!
Thought that this would give people and idea of what they sound like. Also keep in mind that mine hits harder at idle due to the higher compression. Yes, it does sound like a ported rotary at times.
1000rpm idle
https://www.youtube.com/watch?v=brMp3e5kDyM&feature=youtube_gdata_player
1000rpm idle
The r2 cams run and drive just like my bf272's. No strange quirks.... From the logs I have pulled it looks like I didn't loose any spool but now the AFR is running a point leaner than it did previously.
Aem SD. And thanks to Travis and Greg for the help! I was freaking out cause I thought I had a problem and turns out it was me looking at it wrong. My bad guys, thanks again!
Also, after I made a solid lifter and degreed these cams I ended up advancing the intake 3 degrees and exhaust 5 degrees to match the cam card.
Another thing I noticed is my AFR is dead flat under boost just like before the cams except now its 1 point leaner. In that case it should have picked up power everywhere! I will know for sure in a couple weeks when I tune it on the Dyno.
JT-KGY
772
Jan 3, 2025 07:04 PM
evo5+1
10
Dec 18, 2016 02:15 PM
