E5 Weird noise after cam install - pls help
Old Nov 15, 2016 | 06:33 PM
evo5+1's Avatar
Hi Guys
Hoping someone can help.
I recently had cams 272 and hks cam gears installed and a tune on the evo 5.
Impressive results after tune.
But have noticed since then I have this weird noise at idle and when when engine is at operating temperature from the cambelt side.
I have managed to find a youtube vid that sounds exactly like my issue and same weird noise/sound that I have :
Hope you can help
Old Nov 25, 2016 | 10:06 PM
evo5+1's Avatar
Anyone ?
Old Nov 26, 2016 | 09:13 AM
manu_le_ouf's Avatar
when using aftermarket cam gears(especially check the bolt lenght, some cam gears are too thick for the OEM bolt on the Billet cams
Old Nov 27, 2016 | 06:45 PM
evo5+1's Avatar
Ok will get this checked
Old Nov 27, 2016 | 07:07 PM
evo5+1's Avatar
Was told possibly balance belt/timing? Has anyone experienced this ?
Old Dec 7, 2016 | 05:10 PM
evo5+1's Avatar
Bump
Old Dec 8, 2016 | 07:17 AM
Slow_Supra's Avatar
something in the valvetrain is not right. I would not be revving it or drive it until you get you find out the cause.
Old Dec 8, 2016 | 09:44 AM
barneyb's Avatar
What I hear in the video is a lifter tapping - kinda common after a cam install.
Old Dec 9, 2016 | 07:06 PM
boostedup's Avatar
did you replace the cam belt tensionser with an OEM item? did you replace the lifters?
Old Dec 13, 2016 | 09:05 AM
Teal2nnr's Avatar
how long as you driven the car after the cam install? we're the lifters bled or anything? it does sound like lifter tick.
Old Dec 18, 2016 | 02:15 PM
Bladey's Avatar
Sounds like lifter tick, make sure when you are changing cams to bleed the lifters
DuBBzEvo27
Apr 26, 2015 11:40 AM
TigOLDBiTTies
12
Jan 10, 2012 08:13 PM
chlucero
12
Oct 7, 2010 06:01 AM
blazersman
Apr 7, 2009 11:00 AM
juliancastro
11
Feb 16, 2006 11:23 AM
