HELP! weird screaching noise after evo 9 turbo install
just installed my evo 9 turbo last night and when i finished i took it for a test drive and right when it starts spooling i get this really loud squeal/screaming noise. i checked all the vacuum lines and they seem to be on correctly. can someone help?
i took off the intake today and the turbine spins very freely, no noise at all. i also retightened the j pipe and still same problem. i had an issue when installing, the j pipe was touching the starter and causing it to smoke when i connected the battery. so i used the jack and slightly bent the j pipe away from the starter. ( i needed the car really bad and i couldnt wait to order a new pipe. the j pipe is slightly bent and not equal width because i didnt use a pipe bender. do you think that this little kink would cause this problem? i never try to do **** like this but i was getting really impatient and i was fighting the car the whole time i installed this turbo.
i contacted forced performance to order their evo 9 turbo outlet, im waiting on their reply. my car is using a turbo xs 3.5 intercooler with their pipes, the coupler from the j pipe to the downpipe has a little kink in it aswell.
thanks for all the help guys, if anyone has any further ideas or help it would be greatly appreciated!
here is a video showing the noise. http://www.youtube.com/watch?v=vAuxvKefEiQ
almost, it put a little bubble in the j pipe about .5in in diameter but it didnt burn all the way through. i would hope and pray that all this is is a bent flange... i fell like such a newb since this has never happened to me in the past (dealing with heads/cam ls1's, forced induction is so foreign to me...)
took out turbo and the j pipe flange was bent and leaking bad. well ill never try to bend one of those again.... its so weird that the evo 9 j pipe was touching the starter, has anyone else had that problem?
The evo8 J pipe will touch the starter when installing an IX turbo. Are you sure that the pipe you had on there was the IX pipe and not the VIII pipe? This is the whole reason the IX j pipe is used when installing a IX turbo
the guy who sold it to me said that it was an evo 9 turbo with j pipe and all lines needed for install. he must have switched them on me.... i just got my fp race outlet and im trying to figure out how to get it to work with my licp since its 4 inches longer.
OG
12
Apr 19, 2013 05:39 PM
