Is my Ignition Coil missing the Cup the plugs to the Sparkplug?
Old Aug 23, 2013 | 08:08 PM
Randal's Avatar
Guest
So I was replacing spark plugs and noticed cylinder 2 and 4 utilize the actual coil but when I popped it out I noticed it had a spring at the end that I believe touched the spark plugs and that's how it transfers the electricity. The other two of them which we're the plugs with the long wire had like a cup that clicks onto the top of the Sparkplug. Is my coils damaged or is it like this by Factory?
Old Aug 26, 2013 | 06:51 PM
Randal's Avatar
Guest
Bump
Old Aug 27, 2013 | 07:44 AM
llDemonll's Avatar
pics.
Old Aug 27, 2013 | 08:48 AM
heel2toe's Avatar
Your wording is a little confusing so adding in some pictures would certainly help your case. It sounds like when you are removing the coils they are splitting into two pieces with the bottom half remaining attached to the spark plug. If that is the case, it is ok as I've done that in the past and seems to happen if you dont pull perfectly straight up.
Just make sure that when you reinstall the coils you hear them "click" onto the spark plugs so you know they are properly seated.
Old Sep 1, 2013 | 01:41 AM
Jin4221's Avatar
Thats normal, I noticed that also when I changed my plugs today on my 8
Old Sep 1, 2013 | 12:57 PM
Randal's Avatar
Guest
As you can see the Actual coil has this spring that just touches the sparkplug compared to the other boot that has the actual cup that snaps onto the sparkplug.
Attached Thumbnails Is my Ignition Coil missing the Cup the plugs to the Sparkplug?-image.jpg
Old Sep 1, 2013 | 04:21 PM
llDemonll's Avatar
that's normal
the "main" coil bolts down to the valve cover securing it in place. the second coil just clips onto the top of the spark plug holding it in place
nothing weird about those
gregivq
Lancer Engine Tech
43
Dec 2, 2018 09:23 AM
nybluelancer
Lancer Engine Management / Tuning Forums
Apr 8, 2017 06:13 AM
Ekoy
AEM EMS
27
Mar 29, 2017 10:21 AM
epkx
Jan 3, 2015 09:39 PM
essjEVO
Jun 25, 2011 10:35 AM
