About my evo5 turbo
Old Aug 25, 2013 | 04:08 PM
eddy5201314's Avatar
About my evo5 turbo
Hi, my friend found that my evo5 is not running a stock td05, it's an aftermarket td05 16g, does anyone know what's the different between the stock one and aftermarket one? How to recongnize if the turbo isnt a stock turbo? Aftermarket td05 = GT35 turbo? Sorry I don't know anything about turbos car.
Old Aug 25, 2013 | 04:19 PM
Bladey's Avatar
a td06 16g will be a hybrid turbo, pretty hard to tell that how does your friend know did he fully pull the turbo out? either way a td06 16g is fairly close to the stock turbo, no one even close to a gt35 garrett and anything
Old Aug 25, 2013 | 04:57 PM
He didn't pull out the turbo, so a gt35 is different?
Old Aug 25, 2013 | 08:44 PM
AndyCT9W's Avatar
A GT35 is not a TD05.
Have a look for the ID plate/etchings on the turbo. It is the rectangle-ish part on each of these turbos. The standard evo ones have identification etched into them, some aftermarket turbos have markings here, some don't.
Keep in mind that even if the plate indicates a stock turbo, it only means that is the stock intake housing, turbine wheels and exhaust housings can be swapped to increase the capabilities of stock turbos.
Let us know what you find out, then we can help you further.
Off topic: Where in NZ are you?
Old Aug 26, 2013 | 03:28 AM
Thanks a lot, by the way I'm from Wellington, what about you?
NJ9MR
May 19, 2017 09:28 AM
EvoIX89
Oct 12, 2016 04:53 PM
harlintuliau1
Dec 3, 2013 04:05 PM
Crazyhapa
Sep 2, 2013 09:49 PM
EyeDreamt
30
Oct 31, 2011 11:44 AM
