View Poll Results: Has your Evo's ACD ever had a problem i.e. all three tarmac, gravel, snow lights on?
Yes, it has or is in the process of taking a dump
45
60.00%
No, my ACD has always worked fine
30
40.00%
Voters: 75. You may not vote on this poll
Has your Evo had an ACD problem?
Old Sep 3, 2013 | 06:00 PM
  #31
barneyb's Avatar
Originally Posted by kikiturbo
no, that is not the case at all..
the insides of the pump that are in contact with hydraulic oil are perfect. However, water/salt gets onto the part of the plate that is not sealed by O ring + frequently gets between the motor and the pump...
Also, the small part of the solenoid that is above the O ring corrodes to the pump body..
Thanks for explaining this. I drive an '03 and hence no acd.
Old Sep 5, 2013 | 01:19 PM
  #32
Lancerboy89's Avatar
60k on mine and no issues(knock on wood)
Old Sep 5, 2013 | 03:06 PM
  #33
Mr Chef's Avatar
Yes My ACD showed the 3 green lights of doom about 20k miles ago when it got hot out. When it's cold no lights but still an issue.
I'm sending mine to: http://www.acd-tuning.com/index.html next month to fix finally.
Old Sep 16, 2013 | 04:42 PM
  #34
304MR's Avatar
Spoke too soon, it died! Since post #17 till now. Lol
Old Sep 17, 2013 | 02:28 PM
  #35
blowngasket's Avatar
My Acd pump was fine, my ACD inside of my Tcase was SHOT.
So my Tcase was shot, and i didnt the only logical thing to do and best thing ive ever done on my evo, Scrapped the whole ACD system and got a built Non ACD Tcase, i even replaced my gauges and my ACD button is blacked out, it looks as if the ACD was never even on the car.
Old Sep 17, 2013 | 03:13 PM
  #36
McSlides's Avatar
Veteran: Marine Corp
My pump was running perfect for a long time. I deployed and left it in my garage for 7 months without anyone checking on it. When I started it, everything was running perfectly fine, not even a puff of smoke or sputter, except my ACD. When I start the car it's fine, but after a few minutes of driving all three lights come one. Now, there's been times I've driven for 30 minutes before all came on, and others 30 seconds and the lights came on. Someone from a shop told me that after sitting for a while they get air in the lines and to bleed the valve so that's what I'm going to try soon. Any other suggestions?
Old Sep 17, 2013 | 10:15 PM
  #37
kikiturbo's Avatar
try bleeding the system, but I think you will need a rebuild..
Old Sep 18, 2013 | 06:08 PM
  #38
McSlides's Avatar
I hope i don't. How much do those usually run?
Old Sep 19, 2013 | 01:56 PM
  #39
rebuild kits for the pump are about $200,
Tcase is a bit more, but its usualy the pump.
My bet is you have air in it.
Pref7
22
Jan 6, 2023 04:18 PM
MarylandEvo
31
Apr 16, 2013 12:06 PM
2005evo
For Sale - Part Outs
Aug 22, 2011 08:53 PM
alenewit3928
46
Mar 24, 2011 12:35 AM
LivinloudEvo
Aug 17, 2010 08:57 AM
