steering position sensor?
Old Sep 2, 2013 | 07:53 PM
yacubkep's Avatar
Veteran: Air Force
so I finally read the codes for my ACD in my 9 and it showed code 34 for steering wheel circuit bad.. or something of that sort.
does anyone know where this sensor is so i can look at the wiring? or maybe replace the sensor?
Old Sep 3, 2013 | 07:24 PM
cwyteboi's Avatar
It is the steering angle velocity sensor and it is locate behind the steering wheel. You will need to remove; steering wheel, column cover, clock spring in order to get to it. Or at least that's what the directions say. Have never had to do this so I don't know for sure.
This sensor is also tied into the acd pump relay. Perhaps you could swap out that relay with a known good one. Who knows, you might get lucky. Hope this helps and good luck.
Old Sep 4, 2013 | 07:01 AM
yacubkep's Avatar
Veteran: Air Force
where did you find the directions? I can't find them?
Old Sep 4, 2013 | 08:14 PM
cwyteboi's Avatar
Oh! Sorry! I was using software from work, just looking through stuff really quick. You could also try this site, http://www.evoscan.com/vehicle-manuals . It may help or not, not sure, I've never used it, but was referred to this site by a friend.
Old Sep 5, 2013 | 12:47 PM
yacubkep's Avatar
Veteran: Air Force
well I checked out evoscan and it showed the sensor being the clock spring.
but on mitsubishiparts.net it has two different part numbers for them
Collision Catalog - 2006 - Mitsubishi - LANCER
steering column, shroud, switches & levers, sensor str angular velocity $94.55
electrical, restraint systems, air bag components, clockspring $163.90
sweet......
Old Sep 5, 2013 | 06:04 PM
cwyteboi's Avatar
Ouch! Sorry! Like I said, it's some how tied into the ACD pump relay, I haven't taken the time to look at a wiring diagram yet though. You try swapping it out and hope for the best.
RA11226
Evo X How Tos / Installations
120
Jun 24, 2022 03:19 AM
nacsa
May 19, 2017 12:06 PM
EVOREZ1992
Feb 7, 2015 04:16 AM
Sikh
Apr 5, 2013 02:53 PM
MY08GSRX
MitsubishiParts.net - WA
Apr 3, 2012 09:24 AM
