Rough idle
Old Sep 5, 2013 | 07:24 PM
OPENA(671)'s Avatar
Rough idle
What could a rough idle mean once my car reaches temp?
Old Sep 5, 2013 | 09:30 PM
J_Striker's Avatar
Big cams!
Old Sep 5, 2013 | 09:49 PM
Viegasjuice's Avatar
Originally Posted by J_Striker
Big cams!
This. My s2's are rough.
Old Sep 5, 2013 | 09:54 PM
joseph143's Avatar
bad afr... weak ignition coil... weak injector... misfire... stuck valve... minor vacuum leak...
do you have a boost gauge? what are your idle vacuum readings?
you could try a power balance test... unbolt your coil packs... start the car... have a friend rev it up to 1500 or so... then one by one remove each coil and record how many rpms it drops...
the lowest drop indicates a weak cylinder...
you can also use injectors but with our retaining clips its harder to pull off...
Domengg Domino
Dec 3, 2016 07:06 PM
Domengg Domino
Dec 3, 2016 07:00 AM
Domengg Domino
Dec 1, 2016 12:07 PM
05EV08
May 20, 2016 10:30 PM
jb988
Lancer Engine Tech
20
May 18, 2016 04:53 PM
