P0134 and P0171 Help!
Old Sep 16, 2013 | 06:18 PM
slammedndirty's Avatar
So when I bought my Evo it had some ebay intake with a k&n filter on it, Hks Tbe and Injen intercooler piping.
I just installed the muse o2 housing with a new donut gasket and bolts
The car ran fine for 2 weeks then I installed a new Injen intake
now I am getting cels for p0134 and p0171.
When I drive my evo and come to a stop of take it out of gear the rpm's go way down to 400 to 600 and then come back up to 800-900 and it idles fine.
at idle my wideband is reading from 10 to 11.6 and you can smell its running rich.
I did a boost leak test today and nothing was leaking.
Please help!!!
Old Sep 16, 2013 | 06:27 PM
90zcrex's Avatar
Sounds like a bad O2 sensor, do you have a datalogging cable and evoscan?
Old Sep 16, 2013 | 06:37 PM
yes i do
Old Sep 16, 2013 | 07:16 PM
i guess in evoscan i dont know what to look for to see if its bad?
Old Sep 16, 2013 | 08:52 PM
wrx2evoIX's Avatar
Interesting mix of codes P0134 is O2 sensor circuit no activity detected and P0171 is System Too Lean. My guess is something didn't get connected properly when you did the intake.
Check your MAF connector is plugged in, if you're using the MAF.
Check your connection to the front O2 sensor is OK.
Check all vacuum and boost lines are connected
Check the BOV connections are not leaking at intake pipe and top intercooler pipe
If all of the above is ok try disconnecting the battery for a while, check/reset base idle
Old Sep 16, 2013 | 10:34 PM
i will try another reset in the morning and see what happens.
Old Sep 16, 2013 | 10:45 PM
also when i went to get my copy of GTA V I plugged my laptop in and ran evoscan and logged both my o2 sensors and they are both reading..??? so wouldn't that mean the one in the o2 housing is working??
Old Sep 17, 2013 | 02:58 AM
wrx2evoIX's Avatar
As long as the front O2 is showing readings in the 0.01 and 0.9 range, cycling up and down then it's probably OK. Unlikely the O2 has gone bad, it was OK before this intake install.
You didn't change your BOV when you did the intake? The BOV is installed the right way, in push configuration?
If you're really rich at idle you're most likely reading airflow at the MAF that isn't getting to the inlet manifold. The ECU thinks there's X amount of air arriving and injecting the corresponding amount of fuel, but if that air doesn't get there you're going to have a rich mix.
Is the filter on the Injen intake oiled? Could the MAF sensor have got dirty/oiled? Get some MAF cleaner and give it a clean.
Old Sep 17, 2013 | 03:14 AM
Fast_Freddie's Avatar
Veteran: Navy
Are you sure you used a diviorced gasket with the muse dump? Check the dump at idle and make sure no exhaust gas is coming outta the dump at idle, if it is, more than likely that is where your problem resides...
Old Sep 17, 2013 | 05:34 AM
egis's Avatar
i had same codes and failed emission test.tuner turned that off and i passed.if you don't like the way car runs then yeah need to find the problem.
Old Sep 17, 2013 | 09:09 PM
I did not change the blow off valve. i am using the perrin recirc valve.
I will try maf cleaner. is there a certain type i should use?
Old Sep 17, 2013 | 09:11 PM
yes i am using a divorced gasket. and no i do not feel anything coming out the dump tube
Old Sep 17, 2013 | 11:23 PM
wrx2evoIX's Avatar
A MAF cleaner like this http://crcindustries.com/ei/product_....aspx?id=05110
GusandoX
Jan 16, 2017 09:34 AM
hotrod11686
Lancer Troubleshooting
Nov 2, 2015 01:31 PM
mrm95
Nov 7, 2014 01:04 PM
JohnRoland
Feb 14, 2012 03:19 PM
reconracer
14
Jan 16, 2011 12:55 AM
