High oil pressure?
Old Oct 8, 2013 | 08:15 PM
Viegasjuice's Avatar
High oil pressure?
Just curious but seems high to me. Idle js about 15-20...normal driving depending rpm/gear is 50-70 ish and under boost it goes past 100(aem oil pressure shows ---) jat curious if all is normal
Old Oct 9, 2013 | 07:23 AM
ILuvJDM's Avatar
That's normal for mitsu. Now if it was any other motor, say an LS based block, you would **** a brick with 15psi at idle.
Old Oct 9, 2013 | 07:33 AM
chu's Avatar
chu
Yes, thats normal.
Old Oct 9, 2013 | 08:22 AM
As in thats too low or high for other cars? I wa more concerned with the pressure under load
Old Oct 9, 2013 | 08:49 AM
chu's Avatar
chu
Rule of thumbs is 10psi per thousand rpm. Stock Evo motor, pressure comes up very quick though. Also depends on your oil weight.
Old Oct 9, 2013 | 09:01 AM
Does that apply for boost situations as well
Old Oct 9, 2013 | 09:36 AM
sujinX's Avatar
doesnt oil pressure also depend on oil thickness
RedLanEVO
15
Jul 14, 2019 08:46 AM
Mohamed Medhat
Feb 18, 2017 11:33 PM
alexeiyreina
Jun 30, 2013 04:06 PM
burchdc
21
Feb 12, 2007 03:39 AM
KILTERMAN
May 31, 2005 11:59 AM
