Transmission fluid
Old Oct 16, 2013 | 07:05 AM
johntrav's Avatar
Transmission fluid
So I looked up the recommended transmission fluid for my 06 EVO IX MR. And when I went to the mitsubishi dealership they gave me something different than what was recommended. The numbers seem to be the same but it's not DIA QUEEN. The LSD gear oil is correct. When I asked the guy he said DIA QUEEN doesn't make the transmission fluid anymore and this is the mitsubishi recommended for the Evo MR's now.
I jus wanted to know if this is the right transmission fluid before I put it in my EVO.
Old Oct 16, 2013 | 07:10 AM
19DB794's Avatar
That's the new stuff now. The part number should be the same. It's still diaqueen but it's in a different container now.
Old Oct 16, 2013 | 07:24 AM
johntrav's Avatar
Thank you. Last thing I want to do is put the wrong fluids in my EVO.
Only reason I question it was because first the guy gave me automatic transmission fluid an insisted it was correct for my car until I made him check again.
Old Oct 16, 2013 | 07:43 AM
gsrboi80's Avatar
You're good mate
http://www.streettunedmotorsports.co...rans_fluid.htm
Old Oct 16, 2013 | 09:27 AM
johntrav's Avatar
Thanks
Old Oct 16, 2013 | 02:38 PM
19DB794's Avatar
I try to avoid buying fluids for the evo from my local dealer. Last time I tried buying fluid for my ACD pump they tried telling me the evo doesn't need that fluid Even though it's clearly marked on the cap for the ACD reservoir.
Old Oct 16, 2013 | 06:05 PM
johntrav's Avatar
Yeah they tried giving me the wrong stuff first. Good thing I did m research before I went. I got fluid for my ACD and knew exactly what I needed for that. My ACD needs a rebuild though.
I bought that because it matched the DIA QUEEN it just didn't say it. I'm glad it's the right stuff.
Where else can I get fluids. I know one local place near me is extreme psi I can buy stuff.
Old Oct 16, 2013 | 11:59 PM
unihappytime's Avatar
Anyone tried this gear oil:
OBERON F808
http://www.oberonlube.com/Auto_Home.htm
Fine oil -> scoll down to gear oil.
Grilla
Mitsubishi TC-SST Discussion
37
Apr 8, 2021 11:00 PM
amir008
231
Feb 27, 2017 02:32 AM
Fuego
Oct 19, 2016 08:40 AM
glen villis
Aug 29, 2016 08:49 PM
Shirish Agarwal
Mar 15, 2013 05:40 AM
