Transmission install done, but is it correct?
Old Oct 16, 2013 | 02:33 PM
TreatsIX's Avatar
Pretty much finishing up installation now.
All except my help now tells me that the fork should not be in the position that it is?
Anyone have any input? The fork is all the way towards the passenger side.
Thanks as usual,
- Phil
Old Oct 16, 2013 | 02:48 PM
mx4life85's Avatar
Give me a few minutes I'll run downstairs to my garage and take a few pictures of mine..
Old Oct 16, 2013 | 03:00 PM
superbovine's Avatar
Unbolt the slave cylinder then push the fork the other way to engage the bearing. Then install the slave.
Unless they borked up the retaining ring on the pressure plate, in which case pound sand.
Old Oct 16, 2013 | 03:07 PM
Czarcasm's Avatar
Is it a brand new clutch? Brand new disk? Brand new flywheel? Or is the whole combo new? Your pressure plate fingers are overstretched or you dont have the throwout bearing seated in the pressure plate.
Old Oct 16, 2013 | 04:55 PM
TreatsIX's Avatar
New pressure plate, new release bearing, new clutch disc, resurfaced flywheel.
Took out the slave, believe I engaged the throwout bearing, reinstalled the slave, but it is sitting in the same position.
Its an ACD with the Monoloc clip.
- Treats
Old Oct 16, 2013 | 05:37 PM
Czarcasm's Avatar
Read from 61 to 64.
http://www.evomoto.com/tech_articles..._article_id=27
You got the disk springs facing towards the drivers side right?
If everything is correct, like I mentioned above, its either the pressure plate fingers are over stretched or the throwout bearing is not seated right in the monoloc.
It can also be the thickness of the disk, what clutch are ya using
Old Oct 16, 2013 | 05:52 PM
donzilla2004's Avatar
Ah, this happened to me too... If you can't get the slave to seat on the monoloc collar better pull that trans again...
Old Oct 16, 2013 | 06:26 PM
barneyb's Avatar
It may take a little more effort to seat the throwout bearing when using a monoloc. I did this a week or so ago and what I did is slip a deepwell socket over the throwout arm to give myself a little more leverage. Then I gave it a big yank and heard a loud snap. After that everything was well with the world.
Old Oct 16, 2013 | 06:33 PM
cfdfireman1's Avatar
This^^^ big yank and click.
Old Oct 16, 2013 | 06:36 PM
barneyb's Avatar
Read from 61 to 64.
Look at #73 - that is absolutely wrong. OP, you must pull the throwout arm toward the driver's side fender to engage the throwout bearing
TreatsIX
For Sale - Cars For Sale
Mar 21, 2016 04:02 PM
ihazamilk
18
Apr 26, 2014 09:37 AM
jlldetroit
Feb 3, 2014 10:29 AM
TreatsIX
Oct 4, 2013 07:53 PM
TreatsIX
Oct 3, 2013 03:16 PM
