Falls flat at 6psi
Old Oct 21, 2013 | 07:45 PM
hiner005's Avatar
Falls flat at 6psi
Running a Garrett 50trim turbo and daily driving it is fine and once I hit 6psi it falls flat on its face. No smoke out of the exhaust have done a compression test and it was fine. Replace PVC valve and it wasn't the issue...replaced cam sensor it was fine. Double checked timing, did a boost leak test, new spark plug wires and plugs...changed gaps from .20-.35 nothing help. A/F ratio is perfect....I need help...what's wrong guys! I want to drive my car and have fun!!
Old Oct 21, 2013 | 08:19 PM
Ramen_Noodle's Avatar
Are you able to log any pulls and see where you might be hitting the "brick wall" so to speak?
Old Oct 22, 2013 | 01:13 PM
hiner005's Avatar
Can't log since we were reduing timing and now it's snowing
Old Oct 22, 2013 | 01:34 PM
Ian0611's Avatar
Sounds like it's a tuning issue.
Old Oct 22, 2013 | 02:08 PM
hiner005's Avatar
The tuner is my buddy back in WA and he pulled all the tunes and re scaled to make sure it wasn't on his end and it still checked out. We are reduing the boost leak test this weekend as well
Old Oct 22, 2013 | 05:30 PM
Ian0611's Avatar
What boost controller and wastegate are you using? Check the lines and make sure they're hooked up properly. Also, check the tune to make sure the boost cut is set properly.
Old Oct 22, 2013 | 06:02 PM
TheBigD's Avatar
my car did that.. except i built full boost and didnt go anywhere like i was hitting the brakes.. my issue was my crank posistion sensor trigger plate was on backwards....... damn first time motor builds.. lol
Old Oct 22, 2013 | 07:38 PM
impact blue's Avatar
Replace your maf . They can go bad and cause that issue you still have it on there.
Old Oct 22, 2013 | 10:26 PM
hiner005's Avatar
Originally Posted by tormaschy15
my car did that.. except i built full boost and didnt go anywhere like i was hitting the brakes.. my issue was my crank posistion sensor plate was one backwards....... damn first time motor builds.. lol
Lol. Yeah I'm looking to check all avenues of approach on this one. If we figure it out I'll let you guys know. Thanks for the help so far
Old Oct 23, 2013 | 10:49 AM
TheBigD's Avatar
yeah easy to check, if you cant get your motor to go in time its probably on the wrong way.. haha or make it TDC with the crank pulley then look to see where trigger plate is at.
and also check your cam position sensor, like as in the little trigger plate, that its not 180 deg off, idk if it can cause that, but its something to check.
if its ether of them id clean and check maf, maybe your knock sensors loose and causing it to pull a bunch of timing. idk thats all the thing is checked when it happened to me
ChanceR
10
Aug 12, 2011 10:04 PM
MarkDK1
Feb 3, 2011 12:09 PM
korpzjuggalo
19
Jul 21, 2010 02:56 PM
deuce329
May 10, 2009 06:00 PM
bmojito
Jul 7, 2008 01:36 PM
