How many wires is safe to run to your tac fuse?
Well I installed my boost gauge the other day, and the pos used 3 power cables. I wired them all into the tac fuse because it was late and I was tired
. I'm planning on taking 1 wire and splicing the 3 power cables into it. I also want to install an oil temp gauge which will use a similar amount of cabling. For simplicity sale I want to also wire that into the dash fuse. I guess I'm asking, how much can I tap into the fuse before its too much?
What?
Why not do it the "proper way" and use an add-a-fuse at the passenger compartment fuse panel?
This way you're not cutting up the wiring harness on the car in case you want to undo it
You should be fine. To check you need to measure the amount of current being drawn with everything on that fuse active. Then see how much the max draw of the combined gauges will be. Add the current draw without gauges to what the gauges will draw. If it is less than the max rating of the fuse you are good to go.
proverb
14
Jun 4, 2018 11:36 AM
mrwickd123
Evo X How Tos / Installations
11
Nov 2, 2016 10:19 PM
EvokidIX
Mar 12, 2016 04:08 PM
jake33
Mar 17, 2015 03:35 PM
evo86
Sep 27, 2005 11:25 PM
