Engine problem
Old Nov 13, 2013 | 04:33 PM
randomdriver's Avatar
Engine problem
I am a newb with an evo 8. I just found out that my ignition was blown but came to find out that the spot that holds the spark plug will not tighten the spark plug up. Seems like theres no thread to twist the spark plug into as it just drops in. Is that the cyclinder header or is it the block? Help need asap.
Old Nov 13, 2013 | 04:47 PM
superbovine's Avatar
Threads are in the cylinder head. It is probably repairable, but it isn't really safe to repair on the car, it needs to come off the block.
Better option is to get a good head; the repair might hold, but I'd be thinking about that thing every time I went into boost.
Old Nov 13, 2013 | 04:53 PM
do you have an suggestions on what type to get? after looking at the parts and stuff it did look like the cyclinder head but i'm afraid it might cause more damage to the block also.
Old Nov 13, 2013 | 04:59 PM
Terror Rising's Avatar
The aluminum that used to be the threads went somewhere. And that somewhere is your engine/turbo.
Old Nov 13, 2013 | 05:31 PM
I'm asking for help not for comments that people want to make jokes out of.
Old Nov 13, 2013 | 05:48 PM
I wasn't making a joke. I was saying that the aluminum didn't magically disintegrate. You stated that you were worried about damage to the block and I was confirming that possibility.
Old Nov 13, 2013 | 05:55 PM
I understood. I thought it had threads on it but if it were to have an aluminum thread that can be replaced or does it happen to say that i would need a new cylinder head.
Old Nov 13, 2013 | 06:23 PM
ineedboostman's Avatar
The threads are stripped out in the valve cover. It's actually magnesium not aluminum. Either pull the valve cover and put a helicoil in it or I wold just do it on the car. Doesn't take alot of time.
Old Nov 13, 2013 | 06:25 PM
My bad read it wrong not the valve cover. I think you maybe be able to get some sort of helicoil for the spark plugs not sure thou maybe someone else will chime in.
Old Nov 13, 2013 | 06:50 PM
Now that you mention it and i googled on fixing threads. Is it possible it might just be a good fix instead of buying a new head?
Old Nov 13, 2013 | 06:54 PM
apagan01's Avatar
Take it to a machine shop
Old Nov 13, 2013 | 08:58 PM
barneyb's Avatar
It is the cylinder head and stripped spark plug threads are way common. It is repairable. Have the car hauled to a good shop and bring money.
Old Nov 14, 2013 | 06:26 PM
do you think i have to buy new ignition coils or will they replace that for me to.
Jovan Caro
Mar 28, 2017 09:51 PM
guapoholic
24
Feb 24, 2017 07:47 PM
Evoguy!123
Jul 20, 2016 07:26 AM
sanderson
Aug 10, 2009 02:58 PM
goofygrin
22
Jan 6, 2009 12:33 AM
