Anyone know if they make a GoPro license plate holder?
Old Nov 14, 2013 | 05:52 PM
whotippedmycow's Avatar
Anyone know if they make a GoPro license plate holder built for a Evo 8/9 (I would like one that I can mount long euro plates in for the next time I goto the Nurburgring)
Old Nov 14, 2013 | 09:44 PM
galantman03's Avatar
The suction cup isn't good enough?
Old Nov 14, 2013 | 10:08 PM
killerpenguin21's Avatar
Proto makes one for us plates, not sure about euro plates tho.
Old Nov 14, 2013 | 10:20 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Does this work?
http://www.rallysportdirect.com/Prot...-GoPro-Cameras
Old Nov 15, 2013 | 07:53 AM
hatesposers's Avatar
Originally Posted by golgo13
No
From the link you posted:
Proto License Plate Camera Mount Patent Pending
This mount will only fit USDM automotive license plates. These will not fit motorcycle plates.
Old Nov 15, 2013 | 08:03 AM
llDemonll's Avatar
what's wrong with the suction cup?
Old Nov 15, 2013 | 08:46 AM
I don't think anything will be wrong with it but im just worried about losing a 200-400$ gopro going around the Nurburgring. Also I am trying to hide it since your not supposed to record with personal devices but everyone does
Old Nov 15, 2013 | 12:06 PM
llDemonll's Avatar
record with a camera from in-car then. a camera on the license plate is not subtle at all
also, that suction cup is damn good. even trying to get the thing off after using it I have to carefully (and semi-forcefully) jam my finger under it and work it in there. if i tried to pull it straight off I'd be scared it would pull a body panel with it. there's no way it's coming off due to the wind resistance of that tiny camera
Old Nov 16, 2013 | 03:20 AM
vgm10's Avatar
The suction cup is very strong. I have mounted GoPros on body panels many times with success, with speeds in excess of 280kph. But I have also seen some suction cups loose adhesion while in use! The key is to find a rigid surface that is as flat as possible. I had one suction cup release its adhesion while running, because it was mounted on a slightly concave surface, luckily I had taped the suction cup to the body panel (for additional safety).
RallySport Direct
Evo 'For Sale' Miscellaneous
162
Jun 20, 2014 08:34 AM
RallySport Direct
Vendor Classifieds
162
Feb 26, 2014 12:55 PM
Evojj25
Mar 16, 2012 12:17 PM
import_racing
Apr 27, 2011 09:43 PM
EViTZO
Jul 30, 2009 01:35 PM
