Wideband readings??
Old Nov 27, 2013 | 06:29 PM
UnArmed's Avatar
Wideband readings??
Having some problems with my Wideband readings. Idle is between 14.6 and 15.3. WOT 12.2. Is 12.2 ok? And also it jumps all over when I'm not idle or on it. Just cursing it's bouncing all over. Any help?
Old Nov 27, 2013 | 06:40 PM
Raptord's Avatar
Normal for it to jump around a little bit at idle like that. As long as it's averaging around 14.7.
WOT is on the lean side if you're on pump gas. Ideally you want to be in mid 11's or so.
Old Nov 27, 2013 | 06:47 PM
UnArmed's Avatar
Thanks. I bought it with all the mods so im not sure what all done to it but it has a boost controller. can i fix by just turning down the boost?
Old Nov 27, 2013 | 06:53 PM
211Ratsbud's Avatar
What boost is that afr present at?
Old Nov 27, 2013 | 07:01 PM
UnArmed's Avatar
Im not sure to be honest. it has a boost gauge but doesn't work. I just need a temp fix until i can get it tuned next week.
Old Nov 27, 2013 | 07:08 PM
Raptord's Avatar
Not necessarily. Safest bet is to stay out of boost as much as possible until you can have someone touch up the tune.
Old Nov 27, 2013 | 07:10 PM
UnArmed's Avatar
Cool. Thanks.
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
slowonder
Dec 26, 2016 03:04 PM
03BBY1088
Jun 14, 2014 11:32 AM
UnArmed
Dec 1, 2013 08:35 PM
FlaEvolution
10
Apr 26, 2012 06:16 PM
