What is this cut wire by the front drivers side wheel?
Old Dec 16, 2013 | 11:07 PM
URNVS's Avatar
Saw this under the car tonight, anyone know where it goes to/from? ABS sensor?
Old Dec 17, 2013 | 11:25 AM
barneyb's Avatar
yes
Old Dec 17, 2013 | 12:19 PM
URNVS's Avatar
Im going to pull off the wheel tonight then, where is the sensor located that it goes to?
Old Dec 17, 2013 | 12:38 PM
CrusifiX's Avatar
Flux capacitor lead wire. You won't need it unless you go over 88mph... But, yes it is the ABS wire.
Old Dec 17, 2013 | 12:44 PM
barneyb's Avatar
Check the other front hub. You will see where the wire goes and how it is mounted.
Old Dec 17, 2013 | 02:06 PM
kaj's Avatar
kaj
there is a hole on the knuckle, right on top. the sensor is held down with a 10mm bolt. that's where it reads the ABS ring on the axle.
Old Dec 17, 2013 | 06:04 PM
URNVS's Avatar
So...the damn speed sensor is rusted solid into the wheel hub. Any suggestions for getting out out? :/
I already tried PB Blaster, hammering it from the back and a pry bar from the front.
Old Dec 17, 2013 | 07:26 PM
CrusifiX's Avatar
Maybe try a little bit of heat?
Old Dec 17, 2013 | 07:56 PM
Biggiesacks's Avatar
speed sensor aside, ide be more concerned with all that rust!
kaj's Avatar
kaj
you mean the bolt? easy-out or a drill :-(
Old Dec 17, 2013 | 08:29 PM
just in general, that seems like alot of rust. Im on the west coast though, so what do i know...
Old Dec 18, 2013 | 07:37 AM
URNVS's Avatar
Tried heat but no luck. Looks like Im pulling the arm off to either drill or press it :/
No ****, Im in AZ so the cars here have dry seals and rubber but never any serious rust. This thing came from the east coast so its a whole different ballgame.
Old Dec 18, 2013 | 10:04 AM
mithrandir7533's Avatar
Heat will make it expand and just make it harder to get out. Try this, get a can of compressed air and turn it upside and freeze the hell out of it while keeping the hub part warm.
Booztd 3
For Sale - Wheels / Tires
Jun 29, 2015 10:01 PM
thatg
Jul 11, 2013 03:06 PM
eastxcelerate
For Sale - Cars For Sale
31
Jan 29, 2013 04:24 PM
siceclipse
22
Jun 8, 2010 07:59 AM
EnJaNir
Midwest Region
Mar 11, 2009 01:31 PM
