i am looking for LED dome interior lights...
i am looking for LED interior lights...
do you guys think this one will work on my evo?
http://www.lexenauto.com/product-p/w2.htm
has anyone tried something like that? any feedback would be appreciated.
I used a kit like this off of eBay. Cheap and works great. Had them in over 18 months now and they are nice and bright and never skip a beat. Super easy to install. No wiring or anything. Plug and play.
http://www.ebay.com/itm/7pcs-Bright-White-LED-Lights-Interior-Package-Kit-Lancer-Evo-8-9-2003-2007-/170829581887?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2005%7CModel%3ALancer%7CSubmodel%3AEvolution&hash=item27c63c8e3f&vxp=mtr
I just bought this one today.
I will let you know guys know later how it fits!
7pcs Bright White LED Lights Interior Package Kit Lancer EVO 8 9 2003 2007 | eBay
I used a few E-bay light kits, and they just didn't give off enough light for me. They were dim, and they had such a narrow beam pattern that they were pretty useless.
I found some kits in Japan I purchased that are AMAZINGLY bright. They cast a WIDE beam pattern and you can actually see inside my car with DARK tint when it's nighttime with these on. I sold off the two kits I ended up not using... Here are some pictures of the ones I got. They are plug and play.
They are 24 SMD ultra bright wide angle LEDs for the dome, and 8 SMD ultra bright wide LEDs for each of the map lights.
If interested, let me know. I will try and find out if they are still "get-able"
Check out www.superbrightleds.com you just put the make and model of your car and every bulb you need comes up.
Yo guys,I have this kit http://m.ebay.com/itm?itemId=170829581887
7pieces but we have like 3 interior (map lights).where other 4 goes?thanks
here...
these are the ones I'm using for the interiors and plate.
they will NOT fit inside the plastic bulb cover on the plate, unless you remove the double sided tape, ...Is a tight fit but it works.
I have tried other led's for the plate; but a lot of them wont fit inside the cover, and the ones that do fit are not as powerful as these.
http://www.ebay.com/itm/301015702807
trunk (120cm LED trip)
http://www.ebay.com/itm/300894846805
you can get away with a smaller, more compact and less powerful bulb...
but when you are at an empty field at 2 or 3am, playing with rc cars... you need a lot of light
