evo 9 (6-speed) to shepard racing (5 speed) swap
Old Jan 8, 2014 | 05:36 PM
tbryant0226's Avatar
I have a 2006 evo 9 MR. I rebuilt the motor and changed from a 6-speed to a 5-speed shepard racing tranny with a 4.11 final drive. When i got my tranny, i got a tranny, fitments, and a shaft that goes into the transmission. Let me explain this more clearly..
I have a stock transfer case with a shaft that is already in there. So the axle should go right on. On the other side,(tranny side) The shaft(not sure if its called an axle shaft) that came with the order(with a set of splines on the ends) is suppose to go in it(the hole in the tranny). Ill post a pic up. My stock axles do not even fit on the splines!! Please someone tell me whats going on? I appreciate it.
Old Jan 8, 2014 | 05:42 PM
Here's the shaft. And it's hard to take out. Hard to push in. I lined up the splines before putting the shaft in.
Attached Thumbnails evo 9 (6-speed) to shepard racing (5 speed) swap-20140108_184906-1-1.jpg
Old Jan 8, 2014 | 06:03 PM
silver9mr's Avatar
The shafts should go in, some times they need some convincing. Like a rubber mallet or a piece of wood over it and a hammer. But if it's isn't even making it in the littlest bit then those small shafts may be to worn.
Old Jan 8, 2014 | 06:13 PM
thanks! the shaft is brand new and the tranny is brand new. Shepard Racing told me what to do, which I did, and I used the mallet and sledgehammer against wood. Still doesn't work. Im wondering why my stock axles don't fit the new shaft.
Old Jan 8, 2014 | 06:31 PM
Roadrunr's Avatar
If your stock axle does not fit the shaft, why are you trying to install it? Do you still have the old one?
Are you installing it backwards?
The end with the internal threads faces out towards the drivers wheel.
Old Jan 9, 2014 | 08:20 AM
Ecr33's Avatar
Hmm should fit no problem , there the same parts or should be at least
Old Jan 12, 2014 | 08:09 AM
Ok you all were right. It was the wrong side. My transmission guy told me the wrong thing so I hammered it in there. There was no damage to the splines so that's good. The way I took it out was by removing t - case and getting a jack handle and tapping it out, since there was no threads at the end. I appreciate it everyone!
Old Jan 12, 2014 | 03:01 PM
slowsrt4:('s Avatar
Good thing you didn't break anything,
Cheers
Old Jan 13, 2014 | 07:51 AM
Yea everything would have been downhill from then on. I learned that your never really suppose to force anything so that's what made me stop trying it the wrong way. I should have called Sherpad Racing instead of listening to my transmission guy..
rpm_ruffryders
Lancer Engine Tech
603
Mar 3, 2020 07:04 AM
MitsuJoe
468
Feb 20, 2016 11:17 AM
Evo VIII 4o1
Nov 16, 2015 07:49 PM
halfnhalf83
31
Oct 7, 2015 08:23 PM
I4UnderPressure
Jul 5, 2015 06:22 PM
