Tcase fluid change
Like was stated above, it can overfill easy if you pour it in too fast. Get the Flat Rater out of your system when filling the transfer case. You really have to pump it in nice and slow. When you have about .68 quarts in you should start seeing it over flow, You should be fine by then. If you are certain you have poured in over 1/2 quart then you should be ok to know that you have filled it to an ok level.
i ran a hose up through the engine bay, then up to a funnel hanging from my hood latch ring, filled the funnel with the proper amount, took all night to drain into the case 100%, but it worked, it was cold out tho, so it might go easier if the fluid is warmer
Edit: I see the funnel idea now, still seems like a pain. Lift please haha
If you set the car on 4 jack stands in a garage or level ground you should be fine. Atleast that's how I plan on changing out my fluids so I don't have to raise and lower the car over and over.
I will probably be doing it that way from now on.
It wont get too overfilled. Its perfectly fine to jack up on one side to be able to get under the car. Just be aware of the total fluid going in this way you know it wont be overfilled. I think it may be hard to overfill it to the point you will damage something. You would seriously have to want to try to overfill it I think.
