slid into a curb in slow-motion
Old Feb 3, 2014 | 03:37 AM
Turborico's Avatar
i may have been under 5mph when i slid into a curb at like a 35* angle or less. the front passenger side wheel was parallel to the curb when impact occurred. afterwards, it sounded like, a bicycle's brake pads rubbing on its rim. not constant, but pulsating as if it were a very slightly bent rim. it would make that sound from 0-35mph and then disappear. when turning left, it sounded like the tire was rubbing on something along with vibrations transmitted trough the steering wheel but these symptoms occurred only on tighter turns like exit ramps at around 40mph or higher and not at lower speeds. does anyone have a clue as to what it could be?
Old Feb 3, 2014 | 05:15 AM
gsrboi80's Avatar
Did you even look at the wheel? Pull the wheel off and inspect components for damage?
Old Feb 3, 2014 | 05:27 AM
AJsGenerX's Avatar
Wheel Bearing. Get it replaced.
Old Feb 3, 2014 | 05:44 AM
Sharkbite2000's Avatar
Look at your tie rod.
Old Feb 4, 2014 | 12:06 PM
newbieEVO8's Avatar
this
/thread
Old Feb 8, 2014 | 12:42 PM
Turborico's Avatar
sorry, but i forgot to include some info. my first inclination was to replace the wheel bearing. so i purchased a new hub assembly and installed it. Went for a test spin around the block and same noises and vibrations were present.
rognasty
Dec 28, 2016 01:29 PM
RoBear
19
Aug 10, 2016 07:12 AM
JpSpc
Outlander Sport
Apr 23, 2016 06:21 PM
akride907
Mar 17, 2016 02:13 PM
avengerhed
Nov 20, 2006 01:09 PM
