New guy. question
Old Feb 7, 2014 | 09:57 AM
05evoblack's Avatar
New guy. question
Hello EvoM , im new here and got a question. Can you all give me a link or instruction on how to Bleed newly installed ACD pump . Its for my evo 8 . Thanks
Old Feb 7, 2014 | 10:03 AM
Shortbus115's Avatar
Copied this from the thread I found with a quick search:
1. raise car into air
2. top off ACD fluid resevoir
3. remove ACD bleed cap and open bleeder
4. power on ignition (but DO NOT start engine)
5. push accelerator pedal to the floor
the pump will run for ~5 seconds (sometimes longer)... repeat this until all air is bled from system... MAKE SURE THAT YOU DO NOT EMPTY THE RESEVOIR OR YOU WILL HAVE TO START ALL OVER.
to stop pump from running (if it does not stop on its own (depends on ACD ecu type)) you will need to turn off the ignition.
End quote.
I have also read about using a jumper to get the pump going but I have never had to do either so far. Good luck.
Nocturnal One
Jan 3, 2014 09:30 AM
CAD EVO
17
Aug 21, 2013 12:55 PM
rodney007
13
Jun 24, 2013 06:59 PM
QwikEVO
South Region
17
Sep 26, 2012 03:07 AM
