Are the Fp stock frame turbos really worth the money?
So I just ordered an fp red and some other bolt ons to go with it and to be honest they are almost as expensive as a t3 turbo kit even more now that they have changed to a external waste gate. So if you are looking for power and choose to go with an fp turbo because you think it will be the cheapest really add up All of the parts and what you are going to get first. The turbo alone is 2400. This isn't saying that they aren't good turbos just more of a really consider all of your options before you buy what you think will be cheaper because you don't need a new manifold and stuff like that
Maybe EFs but BBKs are more than FPs to start with......
I am picking up a BBK-BB-B and with porting, higher pressure waste gate actuator, and anti surge cover it is damn near $2900!
It really depends what you are looking for. Between a new manifold, custom tubular O2 housing, and BBK-BB-B I will be spending over $5500.....almost buy a whole EFR turbo setup!
I like to stay stock frame and I am not looking for huge HP#s.
It is all preference, not always just about what is cheaper.
Like I was saying the turbos are good and I know I will be happy with my results but most people do the stock frame because they think it will be thousands cheaper but that's not really the case. If you want to keep it looking stock then they are great obviously but if you don't care than you should look into the kits
Unless you are looking for the characteristics of a stock frame turbo......You might be able to get a bigger turbo but it might not be what you are looking for. My advice, find out what you like and then buy accordingly. Just because it is cheaper doesn't mean it is what you want.
Stock frames are for the following IMHO:
1) People who have to pass smog like in Cali
Or
2) People who want a simple setup and aren't looking for more then 450-500ish HP (FP Red and down).
If you are looking FP Black power and are considering getting a new manifold then you should consider a big frame turbo. Lag is overrated on a properly matched twin scroll kit
Or
+1 ^
Im only looking to go to 450 on pump 530 on e85
I have a 25G that is similiar to an fp red and will make the same amount of power. I didnt have $2500 to spend on a new turbo, nor would I pay $1200 for a used turbo due to lack of history, I paid $1100 for my turbo new with a 11.5 hotside port matched from kinugawa.
Once I pay the car off im rebuilding the motor and doing a forward face turbo and attempting 700hp
I would like to run a 6266 turbo or a 35R ball bearing for both and change my setup completely
The only reason I am running a stock frame is because Im in Cali. I was looking into a FP Red but now that FP has changed them up where they aren't as stealthy I might need to look at a bbk now.
I think the general idea is stock frame turbo=quick and easy. You just boot up and play. Where as a t3/t4 kit runs you ~4k
Hell, when I first started lookin at a turbo upgrade I thought stock frame was awesome and cheaper. It all ends up being about the same and you have more room to grow with a bigger turbo. Hence the reason I went for being sold on doing an do black to realizing I'd rather a 6266 instead.
