Disabling ABS using ECU Flash
Old Feb 21, 2014 | 09:26 PM
overdrive1's Avatar
Is there a way to disable the ABS using ECU flash ? There's some issue with my sensors that causing the ABS to kick in all the time. The fuse can be pulled to disable it but then the ABS light stays on which sucks.
Old Feb 22, 2014 | 08:04 AM
Raptord's Avatar
AFAIK the ABS ECU is different from the engine ECU, so I would say no.
Old Feb 22, 2014 | 08:18 AM
jrainwater's Avatar
So take that bulb out of your cluster if it bothers you having that light on so much. And raptord from what I've read on these forums really knows his stuff. I would have to agree with him I know for a fact the ecu and abs ecu are totally different. Do you have acd?
1sxyrxy
Aug 16, 2016 11:03 AM
Evo_Goodness
Aug 3, 2016 04:20 PM
_RMC_
Apr 11, 2014 12:33 PM
evo4mad
Jun 4, 2008 06:12 PM
