Does this seem right to you guys this hp level
The graph seems off. I think with cams, your higher rpm range should not drop like how it looks. something is off. But powerwise, at 21 psi it looks like the correct numbers. Get it tuned on 25 psi or so and you should see higher numbers.
The stock LICP kinda chokes things up. Did you do a boost leak test before you made the pull? There seems to be a weird step just before 3,500rpm. What boost controller, BOV, and turbo are you running?
Doesn't look right at all. You should be over 400whp.
Torque drops from 330 to 180. Why? The engine doesn't have a powerband like that - especially with cams and your other airflow mods. It's literally making less torque with 20psi than it was at 0psi before the turbo spooled. No way.
It looks like somehow your exhaust is plugged, your throttle isn't opening all the way, or something like a misbehaving boost controller is causing you to lose boost.
he has an evo 6, maybe if you put an evo 9 turbo and turn up the boost you will be at 400hp, but with only 21 psi you won't hit 400. Everything looks right to me, but I'm not an expert
Looks correct in terms of peak HP. I think something may be off as you seem to loose alot more hp than mine does in the higher RPM.
I've got, tubular mani, larger front mount and IC piping, megan o2 and 3" turbo back. 21psi gave me about 310
STM Tuned
Feb 9, 2016 06:17 AM
FS[SouthEast]: Buschur 3.5" Street FMIC with Lower Pipe and J-Pipe
Anubis18
Dec 24, 2015 02:23 PM
doncarbone
15
Dec 19, 2015 09:54 PM
04AWDTURBOEVO
Aug 28, 2014 05:30 PM
Pale Horse
Mar 11, 2014 01:21 AM
