No start after winter storage
Old Apr 19, 2014 | 10:09 AM
xPSYCHOxWHITEx's Avatar
Kind of a weird problem because my car ran fine before i put it away. The car trys to fire but wont start throwing codes p0201 p0202 p0203 injector circuit open on cylinders 1-3 but never cylinder 4. the plugs are new and is getting spark, there is injector pulse, the resistance on the injectors checks out fine and the resistor is bypassed. i replaced the cam position sensor with no change. the fuel system was done by rs in Minnesota. If anybody has an idea or has ran across this type of problem before any help would be appreciated!
Old Apr 19, 2014 | 02:30 PM
egis's Avatar
Disconnect fuel supply line from fuel rail,let somebody crank it and watch if you getting fuel.
Old Apr 19, 2014 | 02:54 PM
adriano_917's Avatar
Is this on 91oct or E85 ? Take the injectors out and spray a little bit of wd40 and just a bit of air through the injectors, theyre probably clogged.
Old Apr 19, 2014 | 03:52 PM
I'm on 91 and definitely getting fuel
Old Apr 19, 2014 | 03:58 PM
BlackonBlack2's Avatar
are these high impedance injectors? i'm assuming so.. since resistor is bypassed?..how long was it stored for? I'd try to get new fuel...
Old Apr 19, 2014 | 04:00 PM
egis's Avatar
How do you know without seeing it?do you smell unburnt fuel when cranking?
Old Apr 19, 2014 | 04:49 PM
antij0sh's Avatar
I'd suspect old fuel based on the circumstance but those codes sound like an electrical problem in the injector circuit.
Old Apr 19, 2014 | 05:01 PM
There's a fuel pressure gage on the rail I have the injectors out gonna try that...at worst I can see if the code follows to cylinder 4 when I put a different one in there
Old Apr 20, 2014 | 01:03 PM
Ok I tried blowing a bit of air threw the injectors and switched them around when i put them back and still no start and the code did not follow to cylinder 4. Im thinking the the the ecu witch is locked or the COP ignition control box
Old Apr 20, 2014 | 02:15 PM
MRolla's Avatar
Injectors are no good try to swap your stock ones and see if it starts up
Old Apr 20, 2014 | 08:02 PM
barneyb's Avatar
Mice?
Old Apr 21, 2014 | 09:45 AM
MechTech's Avatar
Depending how you store your car it sounds like you had some critters visit your wiring harness.
Old Apr 21, 2014 | 05:15 PM
I really don't think so the injector wires run into about a one inch loom with what looks like a billion wires and everything else is working
Old Apr 22, 2014 | 02:47 AM
vungvari's Avatar
Bad fuel, bad injectors? Could any critters have gotten in it and chew up the wires?
If bad fuel is your cause you might wanna look into cleaning her out.
Old Apr 22, 2014 | 03:41 AM
WilliSSoiLL's Avatar
I driven mine maybe once in a year with e85 in the tank.took the battery out stored it in the trunk during winter.when I was ready to start up again charged it over night.after two or three cranks fired right up.is your battery good?
