What mods are you MOST pleased with?
Old Apr 27, 2014 | 06:28 PM
  #31
kaj's Avatar
kaj
1. my MAP ef2.5 exceeded my expectations. i didn't expect it to spool as quickly as it does, pack the punch it does, or make the power it does (given my other mods). it was supposed to be a "hold me over" turbo until i could score an FP Red BB. i don't think i'll be getting rid of the MAP until it dies. it's amazing.
2. rebuilding my rear diff. the car exits corners 200% different than it used to. who knew such a quick and easy adjustment would work so well? wow.
3. coilovers or rake adjustment. i installed V3s and set my rake to approx 5mm higher in the rear. i'm not sure which helped as i did them at the same time.. but my car is now VERY neutral. with my Bilsteins/H&R springs, the car pushed like no other. i learned about rake, fixed it, and now the car drives brilliantly through turns.
Old Apr 27, 2014 | 06:35 PM
  #32
kaj's Avatar
kaj
Originally Posted by e_kobz
Everything about the drive is better. The idle, the cruise, WOT pulls, responsiveness, everything. It made the car feel better in every way. I picked up the used coil/carbon fiber version and do not regret it one bit
what are your plugs gapped at? i had the Spoolin' COP and the car seemed to run worse. i swapped the stock ignition on and it ran better. i've never looked back. well.. that and i make less than 400whp right now, so i don't quite feel a need.
Old Apr 27, 2014 | 06:47 PM
  #33
triple L's Avatar
a dyno tune... after a year of saving up and purchasing and installing bolt on parts... nothing beats a dyno tune.... made so much difference....
went from a 8 to 9 turbo, full tbe, injen ic kit/intake, ebay 3.5" ic, spoolinup cop, fftec boost pill, kelford cams, supertech valve springs/ti retainers, walbro 255, fic 1050
made 317whp/326wtq on 91 pump 24psi tapering to 21 mustang dyno
Old Apr 27, 2014 | 06:53 PM
  #34
rodent's Avatar
2.4LR with 6766 turbo and the Varex muffler I just installed. Open exhaust when open, nice and quiet when closed with a push of a button.
Old Apr 27, 2014 | 06:56 PM
  #35
mrowka's Avatar
From: Driving ten under in the passing lane, right turn signal on at all times.
Shifter bushings, or a tune.
Old Apr 27, 2014 | 10:18 PM
  #36
idkmybffjjill's Avatar
the 24.99 or whatever it is for Evoscan. EcuFlash is free but those together are the best mods. They have helped me pick up the most horsepower and since my school has a AWD mustang dyno i run it on the dyno almost every week.
Old Apr 28, 2014 | 06:49 PM
  #37
alleggerita's Avatar
ACD flash, Robispec springs, TRE 12-plate, ER SD tune, Sparktech COP ... and others. But these stand out.
Old Apr 28, 2014 | 10:38 PM
  #38
Capt Leung's Avatar
Shifter bushings were definitely the biggest bang for the buck. My MAP downpipe and ETS LICP exceeded my expectations.
Old Apr 29, 2014 | 10:12 AM
  #39
sujinX's Avatar
flossy griprod, ohlins dfv r/t are my 2 favs.
Old Apr 29, 2014 | 05:08 PM
  #40
9evolution's Avatar
Aquamist hfs3, perrin intake n filter
Old Apr 29, 2014 | 08:03 PM
  #41
kinje's Avatar
Torque solution rear engine mount made shifting feel so much smoother, and also any power mods is always a plus.
Old Apr 29, 2014 | 08:42 PM
  #42
mario009's Avatar
aem ems v2
Old Apr 29, 2014 | 09:11 PM
  #43
Galaxshiel's Avatar
had room for an extra 3 in pipe from air filter to bottom of the front left bumper, decided to throw in a aluminum pipe for extra cold air leading into my filter.
Attached Thumbnails What mods are you MOST pleased with?-20140412_184927.jpg   What mods are you MOST pleased with?-20140412_184921.jpg   What mods are you MOST pleased with?-20140429_205835.jpg
Old Apr 30, 2014 | 05:52 AM
  #44
NJ9MR's Avatar
FCOTM Winner
All my Cusco parts:
*6-point roll cage
*All available chassis bars/braces
*Front Sway bar
I love how tight the car feels and handles...
Old Apr 30, 2014 | 05:59 AM
  #45
IzzyRS's Avatar
Worth it even for those that have shifter bushings and underhood shifter cable bushings?
Tune was my favorite mod
