Popping under WOT and no power...
Old May 6, 2014 | 07:39 AM
  #31
Aby@MIL.SPEC's Avatar
what boost level does this happen at?
is the problem still there if you turn the boost down by 4 psi or so?
did this problem just creep up or did it happen after parts were changed?
Old May 6, 2014 | 10:45 AM
  #32
rodent's Avatar
I didn't realize you still had SES lights. You need to find out whats triggering these first. Did you try to swap the TPS?
Old May 6, 2014 | 02:59 PM
  #33
black_beauty's Avatar
@Aby seemed to be outta no where, pulled hard, flashed a new rom car was lean and acting stupid. Boost level ill have to check the log, but its anywhere between 3800-4200 during spool. @RODENT if my TPS was bad would it still read correctly in evoscan? I checked my cam timing and its fine. I did discover when the car is idling if I wiggle my MAF wires the car goes lean to 10-10.6 and sounds like its about to die? Tuner has told me mafs are junk, but its gonna be more money to tune for speed density, so im trying to figure the problem out before just going SD.
Old May 13, 2014 | 08:30 PM
  #34
Think my problem is solved. Seems it was a bad new plug or a bad connection at the COP...
Old May 14, 2014 | 03:52 AM
  #35
Bhsj13's Avatar
lets hope that everything is good now. let us know!
CNOEVO22
Sep 17, 2015 10:03 AM
nismo3183
Aug 22, 2015 02:50 PM
Faisalm
Mar 23, 2015 02:11 AM
Andrew b
Jul 14, 2014 03:39 PM
