Need help wont start diagnosis
Old Jun 8, 2014 | 09:04 PM
steven121's Avatar
Past week the car has been stopping due to cam sensor code, locAl tuning shop suggest your cams are jumping or something along the lines
Car died due to cam sensor again, I took off the cam cover and saw the belt was loose, so before starting the car I took 2 wrenches to move the gears to tdc to make sure they line up
Upon doing this I heard a click like it jumped but the belt still moved, it did it twice
Cams were lined up tdc tried starting the car and now it just spins freely like its not building compression, everything spins but wont start. Even the turbo will not move
Also here like a release of air like a piff sound
Any ideas? Tomorrow going to realign everything and hope its good. Will do a compression test as well. Maybe a boost leak test to see if valves hold air
Old Jun 8, 2014 | 09:11 PM
GearJamminMR's Avatar
I'd say your timimpng is off now and you're not making any compression. Pull the front cover and check you timing marks and belt. Depending on the miles I would probably just put a new belt on, with tensioner and pullies. If you're not accustom to doing this sort of work on a car have that tuning shop do it.
Old Jun 9, 2014 | 08:43 AM
1UpMoto's Avatar
I definitely would not have tried to start it, take the timing cover off and inspect everything.
Old Jun 9, 2014 | 09:05 AM
Biggiesacks's Avatar
You need to stop and take the car to a shop or get someone who knows what they are doing. Using wrenches to move the cams.... This was just a fail move to begin with. Chances are your belt jumped a tooth and you now have bent valves. Be ready for a head rebuild and a timing belt job at the least. Worst case, you dropped a valve and are going to need a full engine rebuild.
Old Jun 9, 2014 | 08:50 PM
steven121's Avatar
Fixed cams just jumped a tooth no bent valves and car runs great
Yes agreed that was a fail
Cannot believe I did that... Lol took the whole day but im going to build a spare motor anyways for weekend warrior purposes
Thanks everyone
Old Jun 9, 2014 | 09:35 PM
Thanks everyone
How do you know you didnt bend a valve? Also you should figure out why it jumped, your tensioner might be going bad.
Old Jun 10, 2014 | 03:25 AM
steven121's Avatar
It was the tensioner going bad it started leaking already so I replaced it
Old Jun 10, 2014 | 08:50 AM
Yah my tensioner blew its guts out and i skipped one tooth. That bent almost all my intake valves, and there was no way I could tell they where bent till the head was disassembled.
Old Jun 10, 2014 | 09:27 PM
steven121's Avatar
Eventually ill be replacing and rebuilding my own motor soon, just need to pick up a daily and when tax season comes next year ill start my new build
Car seems to run just fine right now so thats all I car about
marinejensen
16
Jul 7, 2015 07:18 AM
heel2toe
46
Mar 24, 2015 04:17 PM
kaj
16
Feb 12, 2012 10:40 AM
moevo9
11
Apr 27, 2010 07:06 PM
Tuner@Swift
Aug 6, 2008 05:38 PM
