Boost pill question
Boost pill question
Does there need to be a boost pill in the vacuum line by the j pipe?
I'm trying to figure out why I can't boost past 14 psi. I've done boost leak tests, changed out leaking seals and changed plugs and wires. Checked the confiuguration of the oem boost controller and vacuum lines. I found a boost pill on the line close to the oem boost controller but did'nt find one by the j pipe. Running out of idea's. Car is completely stock.
I got this car in January with 120k miles. I know I can put a mbc on but before I start modding, I want to make sure everything is in order. Can't believe compression is 160 across the board on all cylinders. What else would hold back the boost to only 14psi?
XstormtrooperX
Jan 19, 2015 08:59 AM
hydroshock
Sep 30, 2009 04:42 PM
