running rich at cruise but idles fine
I've recently changed my setup completely with the exception of the injectors and cams.
Now the car idles fine at 14.7ish but when cruising it seems to bounce around from mid 12s all the way down to high 10s. the only reason i have boost leak checked it yet is bc i need to make a new one for 4inch inlet, which ill be doing today or tomorrow.
I do not have a tuning cable at this time and need to get one.
possible issue?
front 02 sensor?
boost leak?
or that it was tuning with boost leaks and now that i don't have any its running rich?
exhaust leak?
bad wideband sensor?
looking for some input, thanks guys
possible issue?
front 02 sensor?
boost leak?
exhaust leak?
Are you on speed density?
An exhaust leak would show the car as being lean.
Possible that the front o2 is on its way out, mine began to go rich but threw a code immediately.
89turbosupra
Oct 17, 2015 03:57 PM
