Texas Mile
Old Aug 5, 2014 | 07:22 AM
NSDQ's Avatar
Texas Mile
Has anyone done this event or other 1 mile events? If so, what speeds did guys see in Evos? I saw on the website that 2 Evo 2's ran 200mph and 223mph respectively. http://www.texasmile.net/pdf/050511-...rsVehicles.pdf
Old Aug 5, 2014 | 08:28 AM
laramie_05MR's Avatar
I have ran the TX mile several times but only once in the Evo. 167mph stock turbo, cams and E85.
Old Aug 5, 2014 | 09:00 AM
NSDQ's Avatar
wow so it's probably reasonable to assume I could reach 170+ with my mods then?
Old Aug 5, 2014 | 10:40 AM
I would think so. Have you ever used the speed to gear calculator? I see you have a 64 block and an ultimate ratio trans.
Old Aug 5, 2014 | 12:21 PM
NSDQ's Avatar
I have not. Where can I find it?
Old Aug 5, 2014 | 12:26 PM
NSDQ's Avatar
found one, but not sure what the gear ratios are for the shep trans with ultimate ratio
Old Aug 5, 2014 | 02:53 PM
NSDQ's Avatar
Got the gear ratios from Shep racing and plugged everything in on a calculator I found. It estimates I could hit 177mph. That was based on the gear ratios, shifting at 8000rpm, and a 245/40/18 tire diameter. With the 2.4 block I have longer rods and for racing purposes I usually go to 8k rpm before I shift and would do the same in the mile. Normal DD I usually don't go past 6k rpm but my engine will rev safely to 8k no problem. If I got ballsy and took each gear to 8500, it projects 189. Realistically I think between 177-185 is do-able.
Old Aug 6, 2014 | 01:17 PM
You should be good for 170+. Make sure you take the wing off.
Old Aug 6, 2014 | 01:46 PM
NSDQ's Avatar
Went wingless 2 weeks ago
Old Aug 9, 2014 | 02:26 AM
Ivan MR's Avatar
Just curious as to why you should take the wing off? Does it not help in high speed or will it slow you down??? I know the wing does not start to working until 120 miles per hour.
Old Aug 9, 2014 | 06:01 AM
Roadrunr's Avatar
Wingless?????
Old Aug 9, 2014 | 07:22 AM
The 9 wings seem to break in the center under sustained high speeds.
Old Aug 10, 2014 | 08:02 AM
NSDQ's Avatar
Originally Posted by Roadrunr
Ok...was that guy wingless?
Old Aug 10, 2014 | 08:32 AM
Roadrunr's Avatar
Uploaded on Nov 3, 2007
A small video of my car spining at the MLR 30-130 day at RAF Marham 03/11/07 - previous run of 182mph went fine, second run i removed the rear spoiler as it was bending alot at high speed; i hoped it would give me another 10mph, instead it gave me zero down force and zero stability once i came off the gas! Took a deep breath and held on until the ride finished!
Some stats from the V-Box data logging:
I lifted at 183mph and it only took 5mph for it to become unstable and went into a spin at 168 mph.
Maximum spin angle was 142.55 degrees at 114mph before starting to spin back the other way.
The spin lasted over over 330metres.
Old Aug 10, 2014 | 07:19 PM
NSDQ's Avatar
I didn't go to the youtube channel, I'm assuming that's where you got the blurb about what happened? At any rate 4 bolts and I can have the wing back on if I so choose
