Tourque Solutions - Trans Mount Question
Old Aug 16, 2014 | 01:15 PM
eXtreme-Speed's Avatar
Hey Guys,
I'm in the middle of installing all 4 Torque Solution Mounts. I have a question about the Transmission mount.
I have already removed the studs and have installed the Trans Mount on the tranny, but not to sure on the Torque Specs, I don't want to over tighten them since these bolts go right into the Aluminum on the trans.
I just have them on Hand Tight, they are pretty tight on there. Just making sure what everyone else has done.
Thanks!
Old Aug 16, 2014 | 02:30 PM
TommiM's Avatar
47 +/- 7Nm ( 35 +/- 5ft lbs) for the nuts that hold the mount on the transmission side.
82 +/- 7Nm ( 61 +/- 5ft lbs) for the bolt and nut that hold the mount to the chassis.
Old Aug 16, 2014 | 05:00 PM
82 +/- 7Nm ( 61 +/- 5ft lbs) for the bolt and nut that holds the mount to the chassis.
That is not what i need, The studs have been removed so there are no nuts anymore. The Torque Solutions Trans Mount includes 4 new bolts, right now i have them pretty tight, but unsure if any one has torqued them harder.
Thanks for the info, but i already knew that.
Old Aug 16, 2014 | 07:20 PM
TommiM's Avatar
I would imagine that even though those mounts use bolts to replace the oem setup, the tq rating should be very similar so long as the new bolts are same diameter as the studs they are replacing, which they should be. But FYI, just snug them down with a decent sized 3/8" ratchet and you will be fine.
kylefowlie
Jan 3, 2017 10:37 PM
Paulevo9
Oct 30, 2016 11:15 AM
Early EVO
Mar 10, 2015 03:11 PM
johnnnyjeans
Jan 1, 2013 10:39 PM
armysoldier1073
13
Jul 15, 2010 04:22 AM
