Exploding spark plugs.
Old Aug 30, 2014 | 11:08 PM
Evotsx's Avatar
Hi all , new to evolutionm and I regret to inform that my first thread is not a positive one.
The long and short of it is as follows.
I was driving last night at approximately 60kph. When a deafening crack occurred. Immediately I pulled over and began inspecting.
The car was running horrendously rough and the sound terrible. Shutting the engine down immediately I opened the bonnet to reveal that the engine cover had been blown off by the no 3 spark plug from the left.
After managing to put it back in I nursed it home. The trip was terrible rough idles and a wrx sounding engine.
This morning looking at the plug it was revealed to have zero gap in it. To make matters worse the threading in the head is now screwed.
I have no idea how this occurred any light shed on the situation would be greatly appreciated to avoid further headaches.
Thanks in advance evotsx.
Old Aug 31, 2014 | 09:30 AM
Shortbus115's Avatar
Does it look like something made contact with the spark plug?
Old Aug 31, 2014 | 01:04 PM
slowsrt4:('s Avatar
it sounds like you may have had alot of detonation and heat inside the motor which may have blown out the spark plug. Please list your mods as well as your recent tune logs if you have them available.
Old Aug 31, 2014 | 10:01 PM
Evotsx's Avatar
Hi there,
I had the car towed to the mechanics this morning.
They are talking about removing the head and replacing all the internals and machining it.
Upon closer inspection there were some aluminium shavings in the spark plug hole.
The plug was completely intact, I firmly believe that the issue was an over tensioned plug as on idle the car would tap and on start up.
Would heli coliing the plug be sufficient to fix the issue or has internal damage already been done ?
Mods currently on the car are as follows:-
Trust titanium TBE;
GReaddy intercooler;
155 Walbro fuel pump;
Exceedy organic clutch;
K&N Airfilter;
Dyno tune - now running 24psi boost;
Old Sep 1, 2014 | 10:25 AM
TommiM's Avatar
You are lucky if there was no scoring of the cylinder bores.
Eartears
23
Mar 1, 2017 11:53 AM
1711902090
Sep 13, 2013 09:32 PM
whitedemon
Jun 4, 2011 12:29 PM
bloody_angel1
Lancer Troubleshooting
16
May 19, 2009 07:23 AM
tvor
Mar 5, 2008 01:37 PM
