Light weight race batteries, impractical...
Old Sep 7, 2014 | 05:34 PM
killerpenguin21's Avatar
i had issues with my $50 Deka battery draining...then i realized my positive terminal was not screwed on tightly. now no more issues.
Old Sep 7, 2014 | 06:12 PM
fastfam's Avatar
I thought the pc680 was to small personally. I decided to go with the pc925. Made my own tray out of some scrap. Mounted on side to clear my short route pipes and has been cranking my motor for almost 6 years!!! Only had to charge it once.
Old Sep 7, 2014 | 07:35 PM
Ecr33's Avatar
Listen to the first guy running a miata battery works fine, been using one for more then a year
Old Sep 8, 2014 | 12:31 PM
bbong's Avatar
I have the ETS Kit with their CSB battery. It's ok in Summer/Spring but in winter I had to tender it every night or else I wouldn't start the car in the morning.
Just ordered the Battery Relocation Kit from Summit and moving back to full size battery in the trunk.
Old Sep 8, 2014 | 01:24 PM
EatSleepBoost's Avatar
Originally Posted by NSDQ
I relocated to trunk and run a full sized red top Optima
+1 for this. I use an optima yellow top in the trunk. Battery is over 4 years old and has never needed a jump once. That includes 3 winters of the car sitting for 3-4 months straight. I hop in, cranks fine, fires and runs perfect. I wouldn't bother going any other route for a battery.
Old Sep 8, 2014 | 01:30 PM
e_kobz's Avatar
I have no issues with my ETS mini battery kit, but i'm considering relocating my battery to the trunk so I can run a catch can setup in the original battery location spot.
Old Sep 8, 2014 | 03:13 PM
wowzers's Avatar
Sounds like i have a poor battery / product.
one drive thats 1.5 hours and 7 days sitting… and not cranking sounds a bit less right?
Will it erase the tune on the factory ecu?
Old Sep 8, 2014 | 03:40 PM
e_kobz's Avatar
Changing the battery will not erase/alter your tune.
Old Sep 8, 2014 | 05:06 PM
williedaboss's Avatar
I run a pc680 with a negative disconnector. If I let it sit for 3 week. I need a jump. Looking into a small jumper for my battery.
Old Sep 8, 2014 | 05:20 PM
michaelrc51's Avatar
Just put a battery tender on it, especially if you don't drive it everyday.
Old Sep 8, 2014 | 05:42 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Originally Posted by williedaboss
I run a pc680 with a negative disconnector. If I let it sit for 3 weeks. I need a jump.
That's interesting.
Old Sep 8, 2014 | 07:55 PM
wowzers's Avatar
even if it stays disconnected for long periods?… say 2 - 3 weeks without a battery?
Old Sep 8, 2014 | 08:34 PM
No. Your tune will never get erased. Regardless if you even change your battery out.
Old Sep 8, 2014 | 08:35 PM
Originally Posted by golgo13
That's interesting.
Out of curiosity, why is that interesting?
Old Sep 8, 2014 | 09:07 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
I hadn't heard of people having that problem with AGM batteries when disconnected.
