My antenna broke....need questions answered
Old Sep 18, 2014 | 06:28 PM
harp12's Avatar
So my antenna got snapped off and I was wondering where I can get the rubber piece that covers the circuit board in the roof.....please help
Old Sep 18, 2014 | 07:06 PM
WPaDave's Avatar
I feel your pain, I replaced the base antenna piece on a 2004 EVO 8 about two months ago. If you run a stubby antenna there is little give and the base piece is very brittle. The solid plastic base piece breaks off where the antenna screws in. The rubber piece under the base usually does not get damaged.
Mitsubishi sells the rubber piece and the solid plastic base together but they are around $140.
In order to change you have to drop the back section of the headliner, a real pain.
A temporary fix is to use some black silicone to glue everything back together.
Hope this helps.
Old Sep 18, 2014 | 07:10 PM
harp12's Avatar
Yea I super glued the plastic piece but mine doesn't have a rubber piece at least I don't think.....cause I can see the circuit board.....so I put the antenna on and just out electrical tape over my vortex generator antenna hole
amstel78
Feb 2, 2023 10:06 PM
rosuegk7
Mar 14, 2017 07:10 AM
Kwelity
Lancer Troubleshooting
46
Nov 9, 2011 09:15 PM
poon'dEVO
Aug 7, 2011 03:31 PM
heavyD
Mar 21, 2009 03:46 PM
