Ignition coil upgrade
Old Oct 3, 2014 | 07:16 PM
TommiM's Avatar
Originally Posted by cwyteboi
So does the CDI version do away with the wasted spark style of firing order, or does it keep it. I was always confused about that.
Wasted spark can be a PITA because you might have a miss fire on #3, but it's actually because #1 has been toasted. You live, you learn though, oh well!
Good question, I really dont know, but I think it wouldnt change it since that is something programmed into the ecu itself
Old Oct 4, 2014 | 10:40 AM
TheBoz's Avatar
I am running the Spoolin Up Blue CDI system($699 USD). On the stock coils I was having crazy spark issues, once I switched out to the Blue everything has been amazing.
If you are not going to make crazy power the normal COP system will work just fine. I know there are cars into the 700+whp range on the SU COP system.
The Blue is still waste spark. There is no need for direct fire on the evo.
Old Oct 10, 2014 | 08:02 AM
viprez586's Avatar
Get used coils from a corolla or yaris and build the connectors via spoolin up. Go to your local hardware store and fab a plate for them to sit on and get the bolts too.
It's very easy to do and coils are readily available in case one fails.
Old Dec 5, 2018 | 07:51 AM
caz3126's Avatar
you mind posting an Amazon link to both options? please and thanks
Old Dec 5, 2018 | 08:34 AM
2006EvoIXer's Avatar
I don't fully understand the difference between CDI and non CDI, but from what I can find, the CDI basically jump starts the COP by stepping up the starting low voltage (12V) to 250V or more. It looks like the CDI helps provide a stonger spark in high RPMs. So I wonder if there are any power gains at 7000-9000 RPM ranges.
Old Dec 5, 2018 | 09:26 AM
Biggiesacks's Avatar
The way I understand it is that a CDI produces a very short but high energy spark, so it can fire that spark multiple times per ignition event, vs one longer single spark.
LVSBB6
17
Dec 5, 2018 05:30 PM
Thugline
Aug 11, 2010 01:55 PM
RalliartPro
13
Jan 26, 2009 04:08 PM
Boost3dxEvO
32
Sep 23, 2008 04:22 AM
