Just purchased a few mods for my evo, How much Gain should I expect? What do to next?
Hi guys,
So I have an Evo IX. I just purchased these mods should be installing next week If I receive all the parts by this week...
Ported Intake Manifold (Buschur)
Ported Exhaust Manifold (Buschur)
Ported Throttle Body (Buschur)
MUSE LICP/UICP Intercooler piping Kit w/ (Stock BOV)
o2 Housing (No name)
Hallman Pro Manual Boost Controller
Walbro 255LPH Fuel Pump
GSC Beehive springs/ Titanuium Retainers
GSC S2 Cams
Perrin intake
Tanabe Catback Exhaust
OEM Spark Plugs (Not that this will matter)
Samco sports radiator hose
Megan Test Pipe Resonated
1120cc FIC Injectors
E85 Tune
ARP Head Studs
Should I expect a difference on my car? if so, how much of a difference? I will also be tuning my car here.. http://tuningtechnologies.com/ because its 4 hours away from where I am.. (Las Vegas) couldnt find anything else that was recomended on here..
What else should I get? will the FP Green Turbo give me more power? Is it Bolt on? Or do I need to buy more things? e85 conversion kit? I ordered this stuff from reading on these forums.. honsestly have no Idea how much I even spent yet.. Im just excited on getting this stuff on my car! Have had it stuck since I bought it.. 2006.
Thanks to all you guys, have pushed me to upgrade my car. And I cannot wait!
GSC S2 Cams
Perrin intake
E85 Tune
ARP Head Studs
everything will be bolt on. if you know how to replace cams then you will be set, if not TT can do it for you but your car will stay overnight with them. Alfred will set you right. his tunes are safe. he has tuned mine twice prior to my current tune from slowpoke. you should see 330-350ish on 91 octane with that 9 turbo.
Hi guys,
GSC S2 Cams
Perrin intake
GSC S2 Cams
Perrin intake
Oh, dont forget to add a set of at least 1000cc or higher fuel injectors (leaves room for E85 if you want), then add some ARP headstuds so you dont lift your head during 28+ psi on e85. you might as well get a 3.5" front mount intercooler while you are replacing the pipes because you will be removing the front bumper anyway. about the fpgreen, it will be a direct bolt on for you and it will be good for at least 20+ horses over the 9 turbo. sum it down for things you should add:
-3" downpipe
-test pipe for high flow cat
-at least 1000cc injectors
-3.5" intercooler (i recommend ETS)
-ARP headstuds
-replace all clamps to t-bolt style
Good luck and post some results!
-3" downpipe
-ARP headstuds
Hi guys,
GSC S2 Cams
Perrin intake
GSC S2 Cams
Perrin intake
Ported Intake Manifold (Buschur) 150
Ported Exhaust Manifold (Buschur) $200
Ported Throttle Body (Buschur) $300
MUSE LICP/UICP Intercooler piping Kit w/ (Stock BOV) $285
o2 Housing (No name) $40
Hallman Pro Manual Boost Controller $98
Walbro 255LPH Fuel Pump $94
GSC Beehive springs/ Titanuium Retainers $360
GSC S2 Cams $550
Perrin intake $250
OEM Spark Plugs (Not that this will matter) $85
Samco sports radiator hose $40
about $2,466.00 would be my guess.. I honestly don't remember bill isnt here yet. I just ordered a Megan Resonated test pipe also for $70 + $10 for CEL FIX.
that was the plan.. But no it is not safe to do. I will have to rent one of those Uhaul towing trucks and tow it my self all the way to cali. A lot more than I expected to do believe me.
definitely need bigger injectors..and might as well go e85..then turn the boost to max! 30+ psi should be in the 450hp range..but might be pushing that 255 pump might as well go a little bigger to be safe..ur doing about what i had done all last year. if ur thinking about bigger injectors i have some fic 1150s getting rid of.
initialdrew
Dec 14, 2012 03:57 AM
8-BallEvo
62
Jun 13, 2010 02:29 PM
fyreant
69
Aug 20, 2007 08:33 PM
