swapping out EDM evo 7 ecu for evo 8?
Old Nov 4, 2014 | 11:57 AM
envdevo9's Avatar
Hello, does anyone know if i can swap my 2001 edm evo 7 ecu with a evo 8 ecu, is it just plug in? Thanks
Old Nov 4, 2014 | 12:13 PM
alpinaturbo's Avatar
Its not plug-n-play, the Evo 7 UEDM is a little closer to Evo 6 ECU in pin-out.
Check on line pin-outs, to figure it exactly. Ideally you should not have to change your ECU: did it fail?
IS your Evo 7 LHD EUDM? In New York?
Old Nov 4, 2014 | 02:49 PM
todd6027's Avatar
which evo8 ecu ????
Old Nov 7, 2014 | 09:25 AM
sumopower87's Avatar
Definitely a No. Just as the cars look slightly different, so are the ECU's. If you really want to do this you should get in touch with someone who has done ECU re-pining before. Get the ECU pinout of the Evo 7 and Evo 8and compare them and you will see.
If I recall, you will need to get a regular Evo 8 ECU preferably from the US. Don't get the MR as those are different, and please don't get a European version because those are also different from the MR.
LCS
Sep 14, 2015 06:31 PM
MC-Tuner
12
Aug 4, 2014 06:11 PM
rober_x
Dec 20, 2011 06:23 AM
YaroRS
Jan 12, 2011 09:07 PM
mscorei
Sep 5, 2007 11:13 PM
