Lean wot
Old Nov 5, 2014 | 06:58 PM
esad678's Avatar
Lean wot
Hey i am desperate for help. my 03 evo 8 has started going lean wot, afr is 18+, i have changed plugs, fuel pumps, checked the FPR, MAF, Fuel Lines, going to check the injectors tomorrow. anything helps
build:
2.4l stroker
4g63 Head
4g64 Block
OEM 4g64 Crank
Wiseco HD Pistons 9.7:1
MAP Steel Rods
Buschur Ported 65mm Throttle Body
Buschur Ported Intake Manifold
Cosworth Head Gasket
Gates Kevlar Timing Belt
Balance Shaft Deleted
MAP Headstuds
AEM Timing Gears
MAP Oil Cooler
HKS 280 Cams
FIC 1000cc Injectors
Aeromotive FPR
AEM Fuel Rail
Walbro 450
Precision 6262 DBB
Tial 44 WasteGate
Tial Q Blow Off Valve
TTR Intercooler
TTR Exhaust Manifold
AMS High Flow Exhaust
Old Nov 5, 2014 | 07:01 PM
Bhsj13's Avatar
wow don't go WOT until it is fixed. that is super duper dangerously lean! sounds like a fuel issue. Let us know how the injector check goes.
Old Nov 5, 2014 | 07:06 PM
esad678's Avatar
Lean WOT
build:
2.4l stroker
4g63 Head
4g64 Block
OEM 4g64 Crank
MAP Steel Rods
MAP Headstuds
AEM Timing Gears
MAP Oil Cooler
HKS 280 Cams
Aeromotive FPR
AEM Fuel Rail
Walbro 450
Precision 6262 DBB
Tial 44 WasteGate
TTR Intercooler
Old Nov 5, 2014 | 08:34 PM
CT9A PR's Avatar
What type of fuel?
We ran Q16 on FIC 2150cc and IDC2000
Had to switch to twin 450 fuel pump and Siemens 2650cc injectors....however we were around 13 AFR at WOT
Old Nov 5, 2014 | 08:36 PM
CT9A PR's Avatar
What type of fuel?
Old Nov 5, 2014 | 08:51 PM
erald01's Avatar
How does the car drive power wise? Could it be a faulty a/f ratio lambda sensor? Injector duty cycle? Probably maxed out.
Old Nov 5, 2014 | 08:57 PM
esad678's Avatar
currently on 93 pump, and forgot to say I tosses a new o2 in there, compression is 190 across, did a boost leak, and injectors running around 70-80%
Old Nov 5, 2014 | 09:25 PM
420a-t's Avatar
Checked the hose going to the fpr? I found that if the afpr gets adjusted too loose then afrs go super lean. Try tightening the afpr screw a little and see what that does
Old Nov 6, 2014 | 07:35 AM
esad678's Avatar
the pressure on the fpr is reading 43 across the board, give or take a few
Old Nov 6, 2014 | 04:32 PM
hutch959's Avatar
uhhhh.....
was it fine and now all of a sudden its gone lean?
or did you just get it together and its always gone lean.
Old Nov 6, 2014 | 04:37 PM
hutch959's Avatar
43 at WOT?
jtbell86
11
Aug 1, 2020 09:23 PM
Peage
Jan 16, 2015 02:10 PM
Kapoosh1
28
Oct 13, 2009 03:18 PM
Asmodeus6
Oct 28, 2007 11:32 AM
NIevo
14
Sep 25, 2007 03:24 PM
