Gas in my oil !!!
Old Jan 23, 2015 | 07:19 AM
PHILLY EVO's Avatar
Gas in my oil !!!
What would cause gas to get into my oil..... 2003 Evo 8 motor
Old Jan 23, 2015 | 07:24 AM
V8HAHA's Avatar
When a fuel injector is stuck open, the fuel will flood out. Gasoline will definitely get into the oil when this is the case.
or
Any time you realize that too much gas is getting into your engine oil, you should replace the piston rings and then replace the oil. See if this helps the problem, and if it does not, then investigate the many other possibilities as to why the fuel is leaking into the oil
Read more : http://www.ehow.com/how-does_5003081...ngine-oil.html
Old Jan 23, 2015 | 07:26 AM
Ev0ikon's Avatar
My guess is worn down cylinder-wall-to-ring gap.
PHILLY EVO's Avatar
motor was just rebuilt less the 100 miles on it
Old Jan 23, 2015 | 09:07 AM
Ev0ikon's Avatar
Is it still stock bore?
Old Jan 23, 2015 | 11:01 AM
PHILLY EVO's Avatar
no .30 over
Old Jan 23, 2015 | 01:03 PM
Ev0ikon's Avatar
If there is no issue with Piston wall, newly seated rings I can't think of anything else.
Is the car driving/boost fine otherwise? How wide is piston-to-wall clearance?
Old Jan 23, 2015 | 04:37 PM
PHILLY EVO's Avatar
car runs great, was in the body shop for a year, its a Evo 8 motor in my 1987 Porsche 911
Attached Thumbnails Gas in my oil !!!-img_1518.jpg   Gas in my oil !!!-img_1615.jpg   Gas in my oil !!!-img_1579.jpg   Gas in my oil !!!-img_1573.jpg   Gas in my oil !!!-img_1512.jpg
Old Jan 23, 2015 | 07:37 PM
MRolla's Avatar
Bad piston rings or you have a leaky injector. I would check injectors first.
Old Jan 23, 2015 | 08:23 PM
i8acobra's Avatar
With only 100 miles on it, the rings aren't worn in yet. Do a compression test. If the numbers are low, but even, either it needs more time to break in or your piston to wall clearance is too large. If only one is low, you have a more serious problem.
Old Jan 24, 2015 | 12:44 AM
PHILLY EVO's Avatar
This is what it looked like with a very strong gas smell...
Attached Thumbnails Gas in my oil !!!-img_1638.jpg   Gas in my oil !!!-img_1637.jpg   Gas in my oil !!!-img_1634.jpg   Gas in my oil !!!-img_1631.jpg   Gas in my oil !!!-img_1629.jpg
Old Jan 24, 2015 | 09:16 AM
wc351's Avatar
From the pictures it looks like water is getting in to me.
Old Jan 24, 2015 | 01:44 PM
AreSTG's Avatar
I'm with you, that looks like water. When I've smelled "gassy" oil it was a little thinner, but completely mixed and normal color. Unlike water that gives the milkshake & white streaks
Old Jan 25, 2015 | 05:48 PM
PHILLY EVO's Avatar
Ok so I pulled the plugs out and the were black and wet with gas, all 4 were the same. I did a compression test and all four were in the 160 range. Fri I will do a leak down test.
Attached Thumbnails Gas in my oil !!!-img_1698.jpg   Gas in my oil !!!-img_1701.jpg   Gas in my oil !!!-img_1702.jpg   Gas in my oil !!!-img_1705.jpg
pcguru2000
Lancer Troubleshooting
Jan 5, 2018 05:00 PM
Claudius
European Forum
22
Dec 30, 2003 11:17 AM
