Cluster lights replacemnmet
Old Jan 23, 2015 | 07:27 AM
unihappytime's Avatar
Hi Guys, I'm planing to replace my all my cluster light with LED, I think they are all once size.
If they are the same size should I use:
PC74 LED Bulb
https://www.superbrightleds.com/more...panel-led/709/
OR
NEOx LED Bulb - High Power
https://www.superbrightleds.com/more...-led/221/1007/
If the NEO buld which size 3, 4 or 5mm?
I have taken a pic of my cluster and trying to list what each bulb do (see attached)
Do I need to get a matching color with the filters (e.g. green for turn indicator and inter cooler spray) or can i gust get bright white? currently they have the warm white fitments built in them.
Below is a list of what each bulb is lighting up, please feel free to correct and fill in the blanks, I hope this thread will help others doing the same thing.
A - Side / Head lamp
B - Right idicator
C - Rear fog light
D - Left Idicatior
E - High beam
F - Front fog light
G - Intercooler
H - Set Belt
I
J - dash back light speedo side
K - dash back light middle
L - dash back light feul gauge side
M - Battery
N - ABS
O - Hand break
P - Oil
Q - Check Engine
R -
S - ODO back light
T - SRS
U -
V -
W - Door Open
X -
Attached Thumbnails Cluster lights replacemnmet-dash-backlights1.jpg   Cluster lights replacemnmet-evo-dash-side-b.jpg
Old Jan 23, 2015 | 11:03 AM
llDemonll's Avatar
J K L are going to hot-spot really bad. don't replace those with LED's unless you get REALLY NICE 360* ones
I'd keep the stock ones
Old Jan 23, 2015 | 01:17 PM
flippymcbean's Avatar
I would not do it. I hate it. I did mine and just full of regrets. It looks nice, but it's just overkill. The 3 main lights are LEDs, L/R arrows, and check engine light. The light spread sucks. I got my lights from eBay and super bright LEDs.
Old Jan 24, 2015 | 03:22 AM
Which 360 one are good and fit, I don't mind paying more for quality any suggestions?
Ps can anyone see the attached photo? If not I try to re upload
Old Jan 29, 2015 | 04:40 AM
Any good recommendations for a nice bight 360 LED to swap in the dash?
Old Jan 29, 2015 | 07:14 AM
llDemonll's Avatar
there aren't any. there's a reason incandescent bulbs are used; because they have very uniform light distribution
Old Apr 7, 2015 | 10:36 PM
zstryder's Avatar
FWIW, I used these as the main bulb for lighting the cluster and it is fairly even. There's a tiiiiny bit of hotspotting on the left most cluster (speedo) but IMHO still a massive improvement over stock:
https://www.superbrightleds.com/more...l-led/221/995/
(the 5mm in red)
Old Jun 1, 2016 | 03:35 PM
DONNOD's Avatar
(the 5mm in red)
bringing back to life!!! lol
Do they all use 5mm holder? which will be better using the original holder with 5mm LED (200 degree wide) or 1 SMD LED for the warning lights not for the main back lights? For main lights I will get 360 degree wide spread LEDs.
Cheers
Finally, I end up doing mine as well, went with RED SMD Neo Wedge. picture attached above
Old Apr 1, 2019 | 01:46 AM
Bryant89's Avatar
PC74 LED Bulb
OR
B - Right idicator
C - Rear fog light
D - Left Idicatior
E - High beam
F - Front fog light
G - Intercooler
H - Set Belt
I
M - Battery
N - ABS
O - Hand break
P - Oil
Q - Check Engine
R -
S - ODO back light
T - SRS
U -
V -
W - Door Open
X -
Thanks for doing up the guide. I recently replaced my cluster bulbs and I was going crazy trying to figure out why I had more bulbs than "icons"!
Old Jul 9, 2019 | 11:36 AM
meckert's Avatar
So questions for all that have moved to LED's in the dash with the superbrite lights. I recently had all the center dash lights go out-- what this looks like is all the needles in the gauges go black--just the outer rings on the tach and speedo and outer lighting on temp and gas-- no needle lights. Anyone else had this experience with the LED's? -- just dont see how they all all of a sudden burn out at once.
nekkidlad
10
Sep 11, 2015 05:16 AM
jdm_evo8
Dec 23, 2006 07:35 PM
NoTiGuY
May 12, 2005 05:05 PM
