Fuel Pressure to high
Hi everyone, I have a 2003 Evo 8 and just installed a Walbro 450 and a Fuel Lab fuel pressure regulator. The setting on the regulator is turned all the way down and I am still receiving 60 psi at idle. Any ideas? Thanks in advanced.
The regulator adjust's the pressure between regulator and pump, then bleed's off the rest to the return. It will then raie the pressure at a 1:1 ratio per psi of boost. Why do you think a larger return line would make it any better? I would do the feed line. However, i don’t think you need to and the issue is the regulator.
FS[Northeast]: Fuel lab Fuel pressure reg. W/line & fuel rail fitting.
06EvoIXmr07
Jun 20, 2016 08:01 PM
03lances
Lancer Engine Management / Tuning Forums
Apr 17, 2010 12:28 AM
colo_evo
Dec 30, 2007 08:20 PM
EVO MR FU
Nov 15, 2005 05:09 PM
edtxag
Jul 31, 2004 09:14 PM
