bleeding clutch and air only comes through
Old Mar 2, 2015 | 11:34 PM
dspize's Avatar
Hi i have just done a clutch replacement on my evo and have went to bleed it and only air is coming through. so i swapped the slave cylinder over and still same thing? I can't see any leaks from the slave or master cylinder. could this be the master cylinder?
Old Mar 3, 2015 | 03:41 AM
meckert's Avatar
there are two chambers in the mc, one does the clutch, make sure both have fluid when you pull cap off. Also check the floor board--it has to be going somewhere or you don't have any fluid in the system.
9!'clipseDOHC
Aug 29, 2014 11:27 AM
sna08
21
Mar 26, 2012 10:32 PM
Fast_Freddie
Nov 15, 2009 10:56 PM
MREvo2k6
19
May 22, 2007 02:26 AM
MitsuSkot
Oct 17, 2004 06:06 PM
