2005 Evo breaking up in boost
Old Mar 6, 2015 | 07:49 PM
Sdara89's Avatar
Recently purchased a 2005 Evo. I took it on a long trips~ 3000 miles.a check engine light cam on and I pulled the code. Cylinder 1 misfire . I replaced the plugs and ended up changing both coil packs . The car goes into boost just fine in first gear but breaks up in all other gears. Breaks up when I break boost too. I had a vacuum leak from the evap emission purge solenoid but it's fixed now. I'm stumped and need help
Thanks in advance.
Car has 89k on it
Has intake, clutch, exhaust, MBC, evo BOV
Old Mar 7, 2015 | 04:27 AM
evo8426's Avatar
Did you do a boost leak test?
Old Mar 7, 2015 | 05:49 PM
Valentino46's Avatar
1st thing check the Intercooler pipes the all the vacuum pipes check the pipe from your MAF to your turbo.
Also check that the actuator is opening as it should.
Old Mar 7, 2015 | 06:01 PM
MRolla's Avatar
Did you gap the spark plugs.
Old Mar 9, 2015 | 10:27 AM
Sdara89's Avatar
I have not I'll do that later today. Thank you.
Old Mar 9, 2015 | 10:32 AM
Sdara89's Avatar
Yes they are gapped.
IGR7A-G NGK plugs
Old Mar 9, 2015 | 10:33 AM
Sdara89's Avatar
Thank you I'll do that today.
Old Mar 9, 2015 | 11:01 AM
RazorLab's Avatar
IGR7A-G NGK plugs
What gap are they?
Old Mar 9, 2015 | 11:09 AM
Swedin's Avatar
plug gap?!
Old Mar 12, 2015 | 01:51 PM
Sdara89's Avatar
The car is with my family in Michigan and im stationed in Delaware.(usaf) I took a flight back to de cause I didn't want to drive it. I got to wait on my dad to get free time. I didn't gap the Iridium plugs when I got them so im sure they need to be re gapped. will update everyone this weekend, thanks for your help so far.
Old Mar 17, 2015 | 01:07 PM
Sdara89's Avatar
Thumbs up
I Had my dad Re gap the plugs to .23 and he said the car doesn't break up anymore under boost going home this weekend to verify.
Thanks everyone.
Old Mar 21, 2015 | 01:04 PM
Sdara89's Avatar
Car was fine for the first couple pulls now it's back to breaking up
Old Mar 21, 2015 | 01:52 PM
ronaldo9's Avatar
Can you try a tighter gap like .20 or a different spark plug? Looks like you are using iridium plugs, would you consider a copper plug. It shouldn't be expensive so worth a try.
Old Mar 21, 2015 | 03:47 PM
Sdara89's Avatar
Copper plugs didn't work either did more research and trouble shooting and it ended up being the spark plug wires!
Sdara89's Avatar
Iridium plugs gapped to .23
